F-Body Whipple Pics
There are cars running over 550 with maggies. One here with an f body. It will not hit 800RWHP though not that can't no one has is all. It wil not make power over 11#'s of boost. But if you stay around that its hard to beat that. But with you setup a F1 or turbo would be a good choice. I would prefer the F1 from EPP over the APS though. But that is me. Maggie would prolly get you around 550-600 with your current setup with around 8-10 lbs.
And just to clarify, the Maggie kit does not lower the K member. It raises the body from the K member. Drivetrain, steering and suspension is attached to the K member not the body so nothing changes, and the high difference is corrected with a alignment with no problem getting lined in to GM specs
How much low end torque would satisfy your needs? My D1SC setup had too much torque, did nothing but smoke the tires. That dyno was reading the rpm's about 300rpm's slower than the actual tach in the car.
Damn, those are some pretty stout torque numbers for that hp output. If I do go with a centri, it will probably be the F1 A since my motor is built for around 20 pounds of boost.
Kenny Duttweiler made some pretty awesome numbers with that Maggie setup, but I'm not so sure if the 2300 series blowers are out for the f-bodies yet.
https://ls1tech.com/forums/showthrea...ght=duttweiler
Does anyone know if or when they will be available?
How did you manage that torque curve with a centri? Spray ontop?
Jim
#33
His sig says th400, and thats a classic torque curve when a convertor flashes. I have seen cam only cars with spray hit that much torque with loose convertors
