Looking for a scavenging pump;from a incon TT kit or other
Old Jul 26, 2003 | 10:44 PM
Jesse_Boyer's Avatar
Default Looking for a scavenging pump;from a incon TT kit or other
If someone has a pump for oil return from a turbo to the pan, please contact me. I need one ASAP.
Old Jul 27, 2003 | 12:44 PM
red ws6 99's Avatar
Default Re: Looking for a scavaging pump... from a incon TT kit or other
You can use a tilton $180 (or buy the pump directly from flojet for $80) , weldon 9200 $400. I would recommend the weldon. The tilton/flojet pump was designed for pump occasionally pumping water and is not rated fro continous pumping.
Gary
Old Jul 27, 2003 | 08:19 PM
Hopefully I can get buy with this one: http://www.batinc.net/files/pump.pdf
If it's reliable enough to put on aircrafts, it's good enough for me
Old Jul 27, 2003 | 10:34 PM
ArizonaSpeed's Avatar
Any idea what the part number for the Tilton or Flojet is. I looked at the Flojet pumps on their website and most of them seem to be for water only.
Old Jul 28, 2003 | 03:28 PM
personally, i'd go with the one at the link above. It's only 169 and it's made to run continiously... just like the walbro. The Tilton (or Flojet) has been known to cause problems, from what I've read.
Jesse
Old Jul 28, 2003 | 04:18 PM
DaveSchott's Avatar
If you REALLY want one off an incon setup, i'll sell you my very low mileage one, as I plan to go to an aftermarket pump such as the weldon or the link above.
Old Jul 28, 2003 | 08:21 PM
red ws6 99's Avatar
I have an unused tilton, I went directly to the Weldon 9200. Its designed for oil (transmission and rearend) and has adjustable output. Tilton pump is junk, they only make one so look on there webpage. I guess if you don't mind possibly running your engine and turbo go with the tilton.
Gary
Old Jul 28, 2003 | 08:31 PM
Warbird's Avatar
I agree that the Weldon is a superior pump and works well. I haven't had any problems with my Tilton to date except for some leakage, but when it goes I will replace it with a Weldon.
BTW, that pump in the link looks exactly like my Tilton and has the same specs.
