finally got to get a dyno reading.....
Old Mar 31, 2008 | 07:10 PM
red beast's Avatar
Originally Posted by stevewix
If my calculations are correct, the car would need roughly 600 rwhp without the turbo to accomplish this. Can I have the cam specs?! Nice numbers!
I just think the combo is working very well together, I hoped and planned for everything to work together and it looks like it is....I had the motor built, then called the turbo company, they in turn called garrett, then the turbo company called comp cams and had a cam ground....it all just seems to work...
Old Mar 31, 2008 | 07:12 PM
venom ws7's Avatar
What is CR of the engine?? is your heads ported??
More info PLeas anything.
Again Congrats man awesome numbers now post some race vids Pleas.
Old Mar 31, 2008 | 08:54 PM
red beast's Avatar
9.1 to 1, L-92 block 418, L-92 heads ported with bigger valves, comp cams custom grind, garrett gt4508r, L-76 intake 90mm tb and 96 lbs injectors....
Old Mar 31, 2008 | 09:18 PM
NA$TY-TA's Avatar
Hmm
69.2 HP per psi of Boost.....
Saying the motor makes 1HP per CI.
Kyle
Old Apr 1, 2008 | 08:10 AM
camarols1's Avatar
Are you running a factory PCM/Hp tuners ???
I love the build, especially since I'm partial to the L92's
Old Apr 1, 2008 | 08:24 AM
venom ws7's Avatar
Great setup man and with the crappy L76 Intake too.
