Wiring pusher fan for turbo setup
Old Jun 11, 2020 | 07:13 AM
  #41
ddnspider's Avatar
Originally Posted by jayyyw
Nothing. He didn't say it's doing anything extra. Only that the Holley doesn't turn the fan off over a certain speed, only by coolant temp.
It sounded like it was doing something different and thats why you didn't need a lower air dam. For any Fbody thats going to be street driven, the air dam is really important. Running fans at highway speeds is just going to wear them out faster. That's all.
Old Jun 11, 2020 | 01:14 PM
  #42
Dragframe's Avatar
Certainly could. But my daily only see’s 5-7k miles a year (tops) and so this car might be lucky to see 1000. Either case I wouldn’t be too concerned. Never had a fan motor fail on anything yet and I don’t think it’s real common?
The wife’s Denali is the only vehicle I really find critical to keep reliable . She just broke a 100k so I really need to do a vvt delete soon 😒
Old Jun 11, 2020 | 01:21 PM
  #43
ddnspider's Avatar
Stock fans are super reliable, anything aftermarket is a crap shoot but those Derales do seem reliable.
Old Jun 24, 2020 | 04:03 PM
  #44
JoshuaGrooms83's Avatar
new fan harness to properly run after market pushers
doing some positioning. wired the trigger wires to fan one and two wires in the stock fuse block, and then wired grounds and power supplies. had to test which way the fans were pushing though lol not trying to go in there again until i get a s488 in there LOL
all buttoned up. did a test run. one fan truned on once it got up to temp
cleaned up some wires qhile i was in there.
temp stayed at what im assuming 190ish with the one fan on. id have to check out in the tube where the fan actually came on and what the temps were actually at. but so far so good with cheap fans lol i got stock ones on standby if i expereince overheating, but one fan is doing the job at idle for now and it was 84 out.
