Installed 7psi Bov Spring,now It Stays Open!
Old Mar 31, 2008 | 11:09 AM
SPRAYED 01's Avatar
Default Installed 7psi Bov Spring,now It Stays Open!
Im running a tial 50mm bov. It originally came with an 11psi spring. It was too stiff and wasnt opening properly when i let off the gas. So i installed a 7psi spring that works great now driving around town.
My only issue is that now when im just sitting at idle its slightly open and makes a hissing sound. Im assuming this is now a vacum leak. What can i do?
Old Mar 31, 2008 | 11:19 AM
cablebandit's Avatar
cut a coil off the 11psi spring...or half coil increments...or gtet a 9 psi spring
Old Mar 31, 2008 | 11:43 AM
MECHAM's Avatar
take the wg back apart.
the lifter plate at the bottom didnt seat correctly.
Old Mar 31, 2008 | 12:08 PM
lt170chevelle's Avatar
this a BOV or a Wastegate?
Old Mar 31, 2008 | 01:42 PM
SPRAYED 01's Avatar
This is the bov
Old Mar 31, 2008 | 02:03 PM
70Stang's Avatar
It is normal for them to be open at idle...where is the BOV in relation to the MAF (or are you speed density?)
If you are speed density, don't worry about it - if you still have a MAF, you should have the BOV before it - which means it will be fine if it is open.
On the procharged cars, they drive around with the 'blow off valve' wide open in anything but boost, so it is not a big deal...also, all the cars we do that are turbo, it is normal for the Tial to flutter at idle.
Old Mar 31, 2008 | 02:07 PM
MECHAM's Avatar
if you have a set screw on top of the bov you can screw it down.
Old Mar 31, 2008 | 02:14 PM
SPRAYED 01's Avatar
Okay that makes sense. I just wanted to make sure that it isnt going to cause a vacum leak at idle. My understanding is that it wouldnt because the part of the bov that vacum is applied to would be totatly sealed. Is that correct?
MECHAM,
This bov does not have any adjustment screw.
Old Mar 31, 2008 | 02:28 PM
SPRAYED 01's Avatar
Oh ya and it is a speed density tune.
Old Mar 31, 2008 | 02:29 PM
70Stang's Avatar
Yeah, your fine. Don't worry about it!
Old Mar 31, 2008 | 02:42 PM
SPRAYED 01's Avatar
COOL,Thanks.
Alex
