Simple Question:
Old Apr 3, 2008 | 01:16 PM
Silver 00 SS's Avatar
Default Simple Question:
what is the most common reason for blowing a head gasket in a FI application?
to much crank case pressure?
Old Apr 3, 2008 | 08:32 PM
cablebandit's Avatar
detonation due to being to lean or too much timing...generally ....to lean
Old Apr 3, 2008 | 08:42 PM
jerrad's Avatar
Exactamundo.
Old Apr 4, 2008 | 07:01 AM
is it common for to much crank case pressure to blow a head gasket?
Old Apr 4, 2008 | 08:35 AM
camarols1's Avatar
Too much crank case pressure is usually the result of a broken piston and/or ring.
If you have excessive crank case pressure it can contribute to detonation by allowing
too much oil past the rings and into the combustion chamber.
I think that if your tune is on the edge, that the oil mist induced detonation could cause
a head gasket failure.
Lots of variables......
Old Apr 4, 2008 | 10:37 AM
gotcha, now could a broken PCV valve or lack of PCV valve do that?
thanks for all the help!
Old Apr 9, 2008 | 04:08 PM
camarols1's Avatar
Wishful thinking....
Something is probably broken due to running lean and/or hot in a few cyls..
Good luck!
