Has anyone used the AMS-500 boost controller
Even the AMS1000 does not need a laptop. there is only if I rem correctly 3 stages of boost. Its pretty much the same as the AMS 1000 but less boost stages.
The AMS-500 Boost Controller can control 2-Stages and/or levels of boost. The 2-Stages are controlled by Input1 and Input2. Both of these inputs can be configured using a DIP Switch for either Ground or +12 volt activation. Input1 may be configured to function as a “Launch” stage when used in conjunction with Input2. Input2 offers an adjustable ramp rate as well as boost level settings.
Each stage has a range of adjustment from 0 to 40psi with 1psi resolution and is controlled to within .1psi to target using advanced control algorithms. If a setting greater than 40psi is configured the AMS-500 will default to the maximum 40psi allowed. A setting of 0 PSI will turn either stage off.
An optional Safe Mode is available when using a pressure source other than the manifold pressure. The Safe Mode continually checks for the proper pressure increase and will disable the system and open the decrease solenoid in the event of an error condition.
When in Normal Mode of operation the AMS-500 will keep trying to apply pressure to the waste gateuntil its target is reached.
IMPORTANT—The AMS-500 controls the pressure on the Waste Gate so the actual boost level obtained is a combination of the Waste Gate Spring pressure and pressure applied by the controller. (Just like the AMS-1000)
Which one would I benefit from more? Single S91MM car that is 3600lbs. TH400 Auto. Am I going to gain more from the added price?
If its a dedicated strip car I would probably go with the 1000 because it can do so much more.
Thanks!
Im guessing that there is something that I am missing. I cant imagine that the AMS-500 cant do any thinking on its own. At least I hope that isnt the case. Like I said I could be retarded and missing the whole point.
Thanks!
Edit:
http://www.nlrsystems.com/core/docs/...r%20Manual.pdf
This is the install manual from NLR. I dont see anything that would tell teh controller what boost the engine has going to it. So wouldnt it be applying a static pressure that you set?
I guess what Im asking is that how can this be super accurate if all its able to be accurate about is the pressure applied to the top and not whats goin into the engine like other controllers do?
I really like all that i hear about this controller but I wanna understand before I buy anything.
Thanks
Thanks!
Edit:
Thanks
Thanks!
Thanks!
