Is this the radiator everyone uses for turbo applications??
Old Apr 4, 2008 | 04:47 PM
fenix999's Avatar
Default Is this the radiator everyone uses for turbo applications??
http://cgi.ebay.com/ebaymotors/ws/eB...e=STRK:MESE:IT
Just wondering if these are the dimensions everyone's using for standing up the radiator in LS1 fbody's.
(27.5"x15.5"x3")
THANKS IN ADVANCE
Old Apr 4, 2008 | 05:16 PM
Jimmy P's Avatar
It does look like the same one, but why risk buying it off Ebay. That seller has zero feedback. Its only $10 extra at Summit.
http://store.summitracing.com/partde...5&autoview=sku
Old Apr 4, 2008 | 05:21 PM
deadmanTA's Avatar
That looks like it (right size). I wouldn't bid too much over that cause Summit Racing's regular price is like $189.95
Old Apr 4, 2008 | 05:45 PM
fenix999's Avatar
gotcha thanks. yea only reason is because i might be able to go to their store and buy it there (feedback wouldnt be a big deal). i'll see what happens it is better than summit though so thats a plus
Old Apr 4, 2008 | 09:52 PM
Sideways240sx's Avatar
Other plus is you know summit will take care of you.. a dent, or damage, and you will have another one right away.. Good luck on ebay.
Chris
Old Apr 4, 2008 | 10:16 PM
RooRnZ28's Avatar
so is this radiator smaller than the stock one? does it cool better too?
Old Apr 4, 2008 | 10:27 PM
Reject's Avatar
yeah the griffan looks like a hung horse compaired to stocker, it will cool WAY better
Old Apr 5, 2008 | 07:40 AM
deadmanTA's Avatar
Stock radiator is lucky if its an inch thick and the Griffen is 3". The overall width and length is roughly identical, and the stocker is setup to be on an angle and the Griffen is setup the be vertical.
Old Apr 5, 2008 | 10:33 PM
pozesd99''s Avatar
why you buying a new radiator? just reposition the current one straight up and down
Old Apr 5, 2008 | 10:36 PM
Reject's Avatar
cuss the griffen can cool a hell of alot better than the stocker
Old Apr 5, 2008 | 10:45 PM
ddnspider's Avatar
so i take it this wouldnt be a stock replacement because its too thick?
Old Apr 6, 2008 | 12:20 PM
deadmanTA's Avatar
It doesn't bolt-in the upper frame support has to be cut to fit it in. There are very good pics of this in the sticky up top about using truck mani's.
I can't be done; the stockers are made to be on the step angle that they are on. The radiator cap would be facing forwards instead of up if someone tried it.
Old Apr 7, 2008 | 10:46 AM
reamo04's Avatar
i used the 19" one in an LT1. I had to cut the bottom brace as well as the top brace, and then I made some brackets on the bottom to hold it in place. On an LT1, it hangs about an inch down, not sure about an LS1 setup though.
