4.10 gears
Old Apr 6, 2008 | 05:12 PM
hawk584's Avatar
Default 4.10 gears
10bold/4.10/m6/turbo. i hunted around a little bit. from what I've taken in is that 4.10's rev faster and don't utilize as much boost before having to shift over 3.42's... or something like that? there for 3.42's are better, more economical and produce higher horse power #'s?
is it worth getting 3.42's. will the 4.10's hold up or wait untill i can get a 9inch?
i do not plan on drag racing untill i get a 9inch.
Old Apr 6, 2008 | 05:27 PM
DuronClocker's Avatar
What power adder, and what kind of power?
With a turbo, you're going to want a lower gear to put more load on the system earlier in the rev's. It will make you faster if you do it right
For a Procharger, just base gear ratio on your trans, tire, and expected 1/4 MPH.
For a Magnacharger, you can go with a lower numerical gear too because of the massive amounts of low-RPM torque they make.
Old Apr 6, 2008 | 05:38 PM
hawk584's Avatar
hopefully between 500-550rwhp w/custom rearmount
Old Apr 6, 2008 | 05:40 PM
OreoLt1's Avatar
When running a turbo you def. want to go with a 3.42 and possibly a 3.73. I had 4.10's when I fist went turbo and hated it! Shift too fast, you barely use any boost, etc.
Even if you go with a 9in. or 12 bolt you don't want to run a 4.10 because you'll have the same problem but you'll be less likely to destory the rear end unlike a 10 bolt.
Old Apr 6, 2008 | 05:46 PM
hawk584's Avatar
the 9'' is for the drag racing. i have that fear of the 10bold blowing apart.
cool beans. thank you guys for your help. i'll be making a call to the mechanic tomorrow to get 3.42's
