gages
Old Apr 10, 2008 | 10:01 PM
john563's Avatar
Default gages
other than boost gage what else is needed? wideband
Old Apr 10, 2008 | 10:20 PM
Sideways240sx's Avatar
what are gages?
Boost/vac is a must.
Wideband would be a great idea just to watch.
If you have some extra money, oil pressure, water temp, maybe trans temp if your auto.
Chris
Old Apr 10, 2008 | 10:25 PM
DeltaT's Avatar
I like the 3 temps - oil, water, tranny, and oil pressure. I think wideband is iffy in value because you're not sure exactly what rpm the AFR is displaying from. I'd rather datalog for that.
Jim
Old Apr 10, 2008 | 10:42 PM
Websy21's Avatar
First I've heard of those for reccommendations, I always thought the fuel pressure, boost/vac, and wideband were the norm. Trans temp if you were an auto which I jsut order these 4 gagues today. I guess it would depend the application the vehicle is enduring, if you can provide good cooling and not constantly beating on it the oil and water temp could do without. Also, the ambient temperature too of course.
Old Apr 10, 2008 | 10:46 PM
fuel pressure throw on the fuel rail, get it from speed inc for cheap.. i think its marshall.
Chris
Old Apr 10, 2008 | 11:08 PM
Websy21's Avatar
Chris
Ok but what if something go's for **** while you are in the driver's seat? I was going to install one on my rail but thought why? Each to his own, and not arguing either. BTW, too bad your O2 was messed up today. Was curious how she was going to do. You hear allot of blowers on stock blocks but not so much turbo's so I think you should hit your 500rwhp mark with 6-7 psi instead of the 8psi ish that it take from a blower. Good luck!
Old Apr 10, 2008 | 11:42 PM
ninetres's Avatar
Fuel pressure, boost/vac, EGT (if you want to monitor possible detonation), trans temp, oil and water temps.
Old Apr 11, 2008 | 01:31 AM
Websy21's Avatar
Damn with all of those gauges it will be like a space shuttle, LOL
Old Apr 11, 2008 | 06:00 AM
john563's Avatar
I hear yaI do have a trans temp mounted in the went already though.I was thinking boost and wide band.
Old Apr 11, 2008 | 07:01 AM
Websy21's Avatar
This has got me thinking about adding the oil and water temp to my already 4 gauges. I still don't really see the point though, you already have water temp. I know its not that acurate but I mean its close enough to know if you are close to or are overheating the car. As for oil temp, haven't heard of that boiling. Maybe more of a concern with a turbo'd car though.
Old Apr 11, 2008 | 07:15 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I have boost, fuel pressure, and wideband on the pillar, and aeroforce interceptor in the center vent.
Old Apr 11, 2008 | 08:20 AM
ls1290's Avatar
Dumb Ass Vette Moderator
The most important gauge is the wideband, followed by fuel pressure, and then boost. If your A/F, fuel pressure, and tune is good, then there is no real need for a boost gauge.
Keith
Old Apr 11, 2008 | 09:21 AM
ChevyChad's Avatar
I disagree. A boost gauge will tell you if your belt is slipping (SC) or if your wastegate is working properly (turbo)...
Old Apr 11, 2008 | 09:41 AM
deadmanTA's Avatar
I went boost, fuel pressure, and wideband. I want to know if one of those isn't where they should be.
Old Apr 11, 2008 | 11:10 AM
Super Slow SS's Avatar
I went with boost, wideband, and EGT ( I guess this comes from in import days =| )
Old Apr 11, 2008 | 11:22 AM
deadmanTA's Avatar
Then the only gauge needed is a tach the size of a wall clock!
Old Apr 11, 2008 | 11:36 AM
Schantin's Avatar
Keith
Exactly. My WBO2 kept me from torching the engine more than once when I was tuning and is still the most used gauge in my car.
BTW, here's what I'm running: AEM WBO2, Elec FP, Boost, and H2O Temp
Old Apr 11, 2008 | 03:04 PM
macleod's Avatar
pillar pod with fuel pressure/ engine temp/ trans temp. In the middle vents I have boost and wideband. Starts to get to be to much stuff to look at
Old Apr 12, 2008 | 06:48 PM
john563's Avatar
So basically the wide band is a must have
Old Apr 12, 2008 | 07:49 PM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
boost
oil pressure
water temp
trans. temp
fuel pressure
fuel gauge (dont want to much fuel in it!)
fast dual wideband wired into the xfi box
