the ladies like em thick
had to pull it out a couple times. we were going on hopes and dreams that the pan would clear the kmember (bmr) and it does! (nearly)
had to grind the inside of the drivers side 'ear' of the power steering rack bracket a couple times now there is a 1/4" of room all around.
hopefully it will be running tonight
had to put a new front main seal in yesterday afternoon. the seal was not replaced nor damper installed correctly during the rebuild at w2w
while i was in there i also found the cover was not clearanced for the timing chain. it took a little beating but i think is ok.
Glad you got it worked out..
You guys still planning on coming by after the show???
it won't be starting till 1-2.
Kyle
thanks to virginia speed for feeding us saturday night!
monday
k member clearancing / room
tuesday
remote filter
starter clearancing
new tops out roll bar look
yesterday
my buddy dennis took some HD engine and underpinnings shots i will link those when he gets them up.
so ill have to take some time off next week to make it happen
Good luck down there and don't fall to fighting without me!
