YS-Trim + 408 CID
Old Aug 1, 2003 | 08:03 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Default YS-Trim + 408 CID
Would a Vortech YS-Trim supercharger be able to support a 408 CID motor? Also, how interchangeable are the head units? Can I buy the kit for my car and then switch out the head unit?
Old Aug 1, 2003 | 08:48 AM
CHRISPY's Avatar
Default Re: YS-Trim + 408 CID
definitely. YS is a burly biatch
Old Aug 1, 2003 | 10:22 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
The YS trim is bigger than the base LS1 Vortech blower, so you would need new brackets or to modify yours.
Old Aug 1, 2003 | 10:51 AM
ls1290's Avatar
So is the YS-trim a bit of over kill? Would the J-Trim or T-Trim be a better match? Would either one of these use the same brackets? TIA
Old Aug 1, 2003 | 11:54 AM
LS1Tech Co-Founder
Overkill in what way?
Old Aug 2, 2003 | 02:06 PM
supersp0rt's Avatar
i highly highly doubt its overkill. i have a friend who has a 383 with t-trim and at just 6psi he is already overspinning that blower to around 56k rpm's. hte belt is not slipping whatsoever. youre going to have another ~30ci, so ys is what id go to.
Old Aug 2, 2003 | 02:35 PM
aggiez28's Avatar
ys trim would be the way to go imo.... thats whats going on my 383.. plannign to put down 700-800 to the wheels easy
brook
Old Aug 4, 2003 | 11:06 AM
ls1290's Avatar
My only concern with going with the YS-Trim blower is the brackets. How much custom fab is needed to have it work?
Old Aug 4, 2003 | 12:02 PM
BIGBOS's Avatar
I would take to PSJ about this one...his is having chris sikora custom fabbing a lot of stuff for his YS trim build up, he has a 348 motor...planning to run ove 20psi...
