Help on Procharger install LT1
Old Apr 21, 2008 | 08:27 AM
bski224's Avatar
Default Help on Procharger install LT1
Up to the part where I bolt the head unit to heads on a 97 z, It seems my ABS is in the way. Has any other LT1 guys entered this prob. If so whats the best way around it. In the manual it says you may have to grind down bracket, it seems more then that. It looks as if the unit will hit the abs unit?? Its a P600B
Old Apr 21, 2008 | 01:35 PM
Ponyhntr's Avatar
Does your car have traction control? If so, it's not the ABS it's hitting, but the TC module. You will have to relocate or delete the TC when running the blower. Unfortunately ATI does not offer a TC relocation.
Old Apr 21, 2008 | 10:16 PM
bski224's Avatar
YES!! That's what I thought it was and others are telling me its the ABS. I was thinking it was TCS and now its gotta go!!! Any idea, is it easier to delete or relocate??
Old Apr 22, 2008 | 11:11 AM
Ponyhntr's Avatar
I just deleted mine, but I also got rid of the whole ABS unit also at the same time.
Old Apr 23, 2008 | 05:12 AM
EPP's Avatar
EPP
Thumbs up
Not only does it look much cleaner once it is removed, but it takes weight out of the car as well. Bob
Old Apr 24, 2008 | 07:53 AM
bski224's Avatar
Hey Bob, Do you sell a kit for the traction control delete or relocation. Im stuck and I want this procharger installed!!!!!!!!
