oil under vic jr after boost?
Old May 4, 2008 | 11:26 PM
Rickys S/C Z28's Avatar
Default oil under vic jr after boost?
has any one seen this?? it looks as if it might be coming from the knock sensors?
i was thinking that may be it was coming from the valve cover but it is right under the intake and not all over it?? s
Old May 5, 2008 | 05:36 AM
any one?
Old May 5, 2008 | 07:15 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Is the valley cover torqued down correctly? That is my guess.
Keith
Old May 5, 2008 | 07:37 AM
seems to be, is htere any way that oil can come up thow the knock sensers?
Old May 5, 2008 | 08:18 AM
OUTLAWZ RACING's Avatar
oil pressure sending unit crack? How much oil?
Old May 5, 2008 | 09:12 AM
kp's Avatar
kp
There are two rubber seals that seal around the block on the valley cover where the knock sensors are than can get damaged, could be cracked also.
All you can do is take it apart and look for a damaged gasket or something loose somewhere, LS engines arent leakers usually.
Old May 5, 2008 | 11:28 AM
1INSANEGTO's Avatar
There is blocker rings I like to call them that keep the oil from comming up the knock sensor hole. Mine did the same thing because when someone installed them back they put them in wrong. I was running BS3 so I just used expandable freeze plugs. But if your not just pull the intake off it should take less then hr. max
Old May 5, 2008 | 12:50 PM
veee8's Avatar
I welded mine shut. It is coming from the knock sensors. I have seen this before.
Old May 5, 2008 | 05:38 PM
chris-m's Avatar
same here mine leaked and i had them plated over on top of the valley cover as i dont run them.
Old May 5, 2008 | 07:04 PM
great im not running my sensors eather so i think im going to run a plate
Old May 9, 2008 | 06:59 AM
is there a place that makes a plate to by that looks cool?
