STUPID DRAMA issue with my new 370
How about welding another starter ring on the flex plate? A stock flex plate is pretty cheap, just cut the ring off, and weld it on you flex plate. Should be easy and not effect the flex plate any. Besides, I ve only ever had a flex plate sfi cert checked at national events. Even if you put another ring on, it shouldnt "really" effect it, and if you were checked, they probably wouldnt even notice.
--I believe he flipped the spacer plate around on the flexplate
--Machined the bosses on the flexplate
--countersunk the holes on the flexplate where the bolts to the crank go
--machined 1/8" off of the mounting plate on the converter
--machined 1/8" off of the pilot snub on the converter
I THINK that's about it but I'll have him post the details here when he has a chance.
