SDCE How much boost (estimate)
Old May 9, 2008 | 09:40 PM
AFASTYZFR1's Avatar
Default SDCE How much boost (estimate)
Motor is being forged and will have stock heads and 9.5 compression. I have a D-1SC w/ sdce with a 7.25 in crank pulley and 3.4 in blower pulley. I am only going to spin the motor to 6300.........I have headers, tr224, fast 90, and twin 4.5" intercoolers..
do you think this will be over 15psi?
Old May 9, 2008 | 10:01 PM
firehawk618's Avatar
Stock cubes? Maybe. 408 no way.
Old May 9, 2008 | 10:07 PM
AFASTYZFR1's Avatar
yea...347
with the 6-rib and a 3.4" blower pulley (was slipping) I was seeing 10psi on the gauge and 2-bar map sensor was showing 12psi....but then again, I wasn't watching the gauge on the street
I just don't want to go over 15psi
Old May 9, 2008 | 10:56 PM
SilverSS's Avatar
you'll be spinning the blower a little above 55,000 rpm's. I'm gonna say about 13psi. my last 347 set-up made between 13-14psi at 57,000 but that was at a 7,000rpm shift point. 8 rib 7.65/3.85 D1SC with no belt slip.
Old May 10, 2008 | 02:37 AM
Jimmy P's Avatar
It should be about 16-17psi with that pulley combo on a 346. My 402 was seeing about 16.3 with the 7.25" crank and 3.4" blower pulley. Just make sure you don't have any boost leaks, and that the belt is isn't slipping.
Old May 10, 2008 | 08:33 AM
kp's Avatar
kp
With a 222/228/115LSA, 9.5:1 347 I saw around 16psi at sea level at 6300rpm with the D1SC 7.25/3.4. That was with a FMIC so you will probably see a little less, depends on the DA you usually run in as well..
Old May 10, 2008 | 08:48 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
I was seeing 10-11 pounds of boost with almost the exact set up except it was a P1SC. So you will be above that for sure.
Old May 10, 2008 | 10:43 AM
nvmy2000ss's Avatar
I had the same cam with 205 AFR's. With the 3.7 blower/ 7.25 lower sdce I saw almost 15#'s of boost but thi was at 7000rpm. Im sure you would see close to what your looking for.
Old May 10, 2008 | 12:28 PM
Tom@SpeedInc's Avatar
I don't think you will be over 15psi
we saw 13psi with 3.85 and 7.65" pulley setup on an Fbody with D1SC race system.
Old May 11, 2008 | 08:15 AM
AFASTYZFR1's Avatar
thanks everyone....just wanted to make sure I didn't need a larger blower pulley.....hope the 3.4 will make 15 and if not I will find a way
