New Gn owner
Old May 14, 2008 | 07:32 PM
Ls1ChevyII1963's Avatar
Thumbs up New Gn owner
Hey I'm picking up my 87 Buick Grand National this weekend and I have never worked with any kind of forced induction motors. Wanted to ask a few questions.
Are their any extra maintenance that comes with a turbo?
Anything I should look out for while running the car?
The car is pretty much stock with a te44 turbo,cat-back, and drag radials
Any other mods I should look into short of pulling the motor?
Thanks any help is appreciated
Old May 14, 2008 | 07:35 PM
DeltaT's Avatar
Cool, should be fun. For an excellent source of Buick turbo-specific info, check out turbobuick.com.
Jim
Old May 14, 2008 | 07:37 PM
Thanks I'll see what they have to say
Old May 14, 2008 | 07:38 PM
bumpin_records's Avatar
you may wanna check out bgnra.org and turbobuick.com thats all they talk about over there. as far as mods i use to own a grand national. get a front mount intercooler and make sure and i mean make sure you upgrade the fuel system. buick motors dont like being reved high. get a wide band o2 sensor. and you can also get a electric dump right before the cat. and also a shift kit. you should run some real good 11's with that combo.
Old May 14, 2008 | 07:42 PM
Thanks yeah I've already ordered a better pump and regulator. Any thoughts on the stock intercooler? The car runs 12.4 right now daily driven so I'd like to get it into the low 11's so I can play on the street with it.
Old May 14, 2008 | 09:00 PM
98catfish's Avatar
You can easily do it on the stock intercooler. Get a new chip from Eric Marshall (Turbotweak). An upgraded turbo TE45a or equal. A 3600 stall, And alchy if you want to run more boost w/o race gas. We've run 10.50 on a 45a w/ tires and race gas.
My name is Rosewood T-Type on TB.com or you can pm me here.
Doug
Old May 14, 2008 | 09:45 PM
topend's Avatar
Originally Posted by bumpin_records
. buick motors dont like being reved high. .
yeah i know , i only shift my GN at 7600 rpms.
Old May 14, 2008 | 09:50 PM
98catfish's Avatar
Stage II headed no doubt!
Old May 14, 2008 | 10:14 PM
jerrad's Avatar
I'd get a te61 turbo, champion heads, front mount or alky, a 3600 stall and some 60#ers. I have a te44 with some champion heads and the turbo ran out of steam. Beofre the heads I could run 24#'s with alky and now I can't get over 20#'s with the heads.
Old May 14, 2008 | 11:40 PM
BoostnTBSS's Avatar
Guys i got 2 stage 2 motors and 1 gn1 headed built long block and tons of buick stuff our GN runs a best of 8.79@156!!!! and a 61 is a sweet street turbo...
Old May 14, 2008 | 11:51 PM
Thanks Everyone for the info. I pick the Gn up on friday and its going to Hrp that night.
I need some info on a in car boost controller and also how do you determine how much boost I can run without just taking it passed it's limit then knowing.
Old May 15, 2008 | 12:22 AM
Mean87SS's Avatar
If you want, PM me any questions you have... I can get a TE44 to run mid 11's easily...
Or PM me for my number... I tune some cars around here, and my own
Old May 15, 2008 | 12:24 AM
Mean87SS's Avatar
You can run as much boost as you have octane for... for a stock IC, I wouldnt recommend any more then 15 PSI.
I see 20-21 psi on my stock motor car... have seen 28 on 110 octane
Old May 15, 2008 | 12:35 AM
jerrad's Avatar
I always ran 16 on 91/93. With the alky I ran 24#'s on 91/93 with zero knock. If you get an in car controller it will slow your spool some. The closer the controller is to the WG the less lag you'll have.
