Vortech's Aftercooler vs ATI's Intercooler
Old Aug 8, 2003 | 11:32 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Default Vortech's Aftercooler vs ATI's Intercooler
Which one is more efficient for cooling the charge and keeping diffusion of the charge to a minimum?
I am looking at short term runs like the duration of a dragstrip run and not continous running in autocross.
Old Aug 8, 2003 | 12:30 PM
2FAST4U's Avatar
Default Re: Vortech's Aftercooler vs ATI's Intercooler
That is hard to say but I would go procharger, all the aftercoolers I have seen sit over the motor! But in drag racing I have seen many cars with NO intercooler for the blower.
Old Aug 8, 2003 | 12:43 PM
MEAN LT1's Avatar
It depends what your intensions are. If your going to drive the car mainly on the street and occasional dragstrip use. I would go with the air/air intercooler from ATI. If the car is basically track only than I would do the aftercooler and you get to put ice in it for better cooling charge.
Old Aug 8, 2003 | 12:54 PM
StalkerLS1's Avatar
Your going to say this is biased because it's from Vortech but for what it's worth.. Facts are facts.. Read this word for word before you make up your mind..
And for what it's worth.. Heatsoaked in 2 hours of stop and go traffic.. My Aftercooler core is merely warm to the touch.
http://www.vortechsuperchargers.com/...s/science.html
Old Aug 8, 2003 | 01:31 PM
ls1290's Avatar
I am leaning towards the Vortech unit, mainly due to all the C5 belt slipage problems with the ATI setup. Is the location of the aftercooler that important. As long was the coolant temp is 'cool', wouldn't that make the effectiveness of the aftercooler the same reguardless of where it is located?
Old Aug 8, 2003 | 05:42 PM
MelloYellow's Avatar
Road Racing? Air to Air
Weight savings? Air to Water
Reducing tubing/boost loss? Air to Water
Drag Strip? Air to Water w/Ice
Old Aug 10, 2003 | 11:00 AM
ls1290's Avatar
Anyone else.....
Old Aug 10, 2003 | 12:47 PM
Loader's Avatar
I agree - what you want to do with it is part of the equation.
If drag-only, watch the class rules. I just read a power-adder class that does NOT allow intercoolers and does NOT allow cog belts. I think it was at Englishtown.
Personally my experience is only with air-air intercoolers. I've heard air-water are better for chilling. I've also heard of people spraying nitrous across the front of an air-air intercooler to chill it better.
All in all, it would seem that an intercooler that is out front someplace will cool better than a box under the hood and over the engine. It gets hot in there!
Old Aug 10, 2003 | 01:29 PM
True, I don't like the location of the F-Body Aftercooler.
Then again, the water reservoir and water to air heat exchanger/radiator for the F-Body aren't over the engine, just the aftercooler. Water to Air exchanger can be located up front too and water reservoir is away from the heat.
Old Aug 11, 2003 | 08:25 AM
Mark C's Avatar
Air to air in all applications. Air to water in a car is not really air to water, its air to water to air. In a boat, yes. For that reason it can't match air to air.
Now, if you use lower than ambient temperature water, I guess I can see that it could beat air to air, but how the hell do you get ice water into the system?
Old Aug 11, 2003 | 10:04 AM
Irregardless of which has better temps, they say that water is 9x more conductive than air and transfers heat much more efficiently.
So even if air to air might be a bit cooler, it can't conduct/dissipate the heat as well as water.
Old Aug 11, 2003 | 02:59 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
and the big q is...
What combo?
Old Aug 11, 2003 | 03:42 PM
JimmyKash's Avatar
sorry, air/water setups weigh more than air/air setups. You have the water, the pump, the lines, the cooler itself, the tank, and the tubing with all of that
Old Aug 11, 2003 | 07:09 PM
KHShapiro's Avatar
air to air is more efficient.
ice melts pretty quick in the heat of the engine compartment. there are other pulley setups at limit belt slippage..ATI IMO
Old Aug 12, 2003 | 12:32 AM
K, will call it even on the weight savings, but I'll trade that topic for ground clearance on the Corvette. The Air to Water being superior in that respect.
I sit about 1" off the ground. Last thing I need are dual intercoolers scraping everything and knocking the air tubes loose.
Old Aug 12, 2003 | 08:04 AM
ls1290's Avatar
From what I have seen, the C5 ATI kits are having major belt slipage problems. MMS has a new bracket that should fit, but that is another $300. $300 is not a major amount of money, but it is the principle of it that ATI should have done it right the first time.
Old Aug 12, 2003 | 05:55 PM
The C5 ATI's definitely do setup to ATI specs (sucks).
Andy at A&A and Mike at MMS have come up with good solutions for the C5 ATI kits.
I still prefer the Vortech belt and secondary cog system for the C5. If I had an F-Body I'd go ATI.
