Alfred's car... High mounted 101mm
Hmmm. I may as well pull one of my Stand by Thumper Turbo's (from my Ford Days) off the shelf and stick it on the new shop car. I gotta do something to keep up with the madness here on Tech.
-370ci
-8.5-9.1:1
-317 LQ9 heads
-Victor JR inatke
-91.5mm thumper (98mm, 101mm, ????)
-ect, ect.....
I could just call it the "Budget Thumper Build". As much as a build like that can be called BUDGET anyway...
-370ci
-8.5-9.1:1
-317 LQ9 heads
-Victor JR inatke
-ect, ect.....
You change your mind more than I change my socks. One second you have all the parts lined up for a sick shop car than the next minute you are selling it all and going back to stock.
Back and forth, back and forth........................ LOL
Josh, you are worse than a woman!
#37
Here's a vid I found of it:
http://media.putfile.com/Jim-Filipowski
I think Jim's best pass ever was 7.7x @ 193 with a 23 deg headed 368 cube sbc at 3400 lbs on radials and stock suspension. He sold it a little while ago but I'm sure he'll be back with another badass motor as always.
#38
#39
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#40
John with a 348 you can spool a 106 for a full race car. there are lots of ways via timing/2 step ect. to get it moving... with my blow thru 348ci 9.5-1 motor on the engine dyno i could get 10.5 psi @3300 with a S88 turbo with 1.32 ex housing via my step retard and 2 step it was like 1 sec to full boost
the only bad thing was i would over spin the water brake it was rated to 800lbs and i hit that instantly LOL ...
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
