just got my cam specs for my 402 ls2 turbo
Old 05-21-2008, 11:39 AM
pozesd99''s Avatar
Default just got my cam specs for my 402 ls2 turbo
grind # r115.0
238-240@.050 .605-.608 on a 115 lsa
this is going on my set up in my sig
Old 05-21-2008, 12:07 PM
ABeasst's Avatar
damn that thing is tiny for a 402.
Old 05-21-2008, 12:09 PM
LS1TECH Sponsor
DrTurbo's Avatar
To small of a cam.....on a 402 it will be out of rpms/air quick....the turbo will still be pulling if your running an 88mm.
Old 05-21-2008, 12:15 PM
Mekkadon's Avatar
that is a pretty short deg. on exhaust duration??
Old 05-21-2008, 12:25 PM
7 Second Club
NicD's Avatar
Who in the world spec'd that out?
Old 05-21-2008, 12:28 PM
camarols1's Avatar
Way too small, who spec'd the cam.
Looks like a good cam for fuel mileage though!
Old 05-21-2008, 12:33 PM
pozesd99''s Avatar
just talked to the guys at virginia speed and they assured me that that cam is more than enough for my set up. he said with 20-22lbs on my turbo i should be seeing power levels like 1100-1300rwhp on race gas... turbos reach a point to where they aren't as efficient and this cam is more than adequate to push my car to 7000-7200 rpm limit...
on 18 lbs im expected to be around 800-900 on pump gas
Old 05-21-2008, 12:35 PM
Juiced's Avatar
that cam is going to peak way to low to carry to 7k rpm and 1000+ rwhp.
Old 05-21-2008, 12:42 PM
pozesd99''s Avatar
well the builder at virginia speed is a very reputable guy... im sure he knows what he is doing... he's been doing this for a while lol....
Old 05-21-2008, 01:01 PM
Websy21's Avatar
I am sure it will suffice just fine but I'd never run that if I was in your shoes. It call always be better and wouldn't take a genious to spec that one out better. Many go with bigger cams in stock engines and less dramatic FI setups. Until I get my 370 dropped in I jsut finished installing a 22/224 .581/.581 114 LSA on my stock block and I was worried it was too small. Plus I love lope I couldn't dream of going with a smaller cam on my stock engine.
I also don't like reverse split cams in any combo, maybe the TR230 on stock heads and full bolt on's but can't think of any other one. Really I am sure you will be fine though as FI setups make sick power even on small cams. If you plan on spinning to 7k which there is no reason you should be, than yet, you probably will run out of steam up top and have the power fall off.
Heck I'd go with a 03+ Z06 cam before that one myself. I like everything else in your setup though and I'd go with Speed Inc's and a few others big cube turbo grind. Its a 236/236 115 LSA, not sure on lift though. High .59x or low .60x somewhere's in there. Even if you want stock like driveabilty, that cam for a 402 is way small IMO.
You will make sick power but why limit the gains by a baby cam. I'd take an off the shelf cam before that spec'd out one. I myself got one spec'd out by comp for my 370 and I am confindent it will do great in all area's.
Good Luck and enjoy!
Old 05-21-2008, 01:13 PM
pozesd99''s Avatar
well its in my motor already lol hahahaha. i guess we will see how it does on the dyno once the turbo kit is fabbed
Old 05-21-2008, 01:20 PM
Websy21's Avatar
Don't worry about it, it will do fine. It will idle like stock and be a sleeper thats for sure!
Old 05-21-2008, 03:54 PM
pozesd99''s Avatar
lol until they see the intercooler lol hahahahaha, but its only a shiny radiator!!! lol jk
Old 05-21-2008, 04:08 PM
ninetres's Avatar
Why? Ever ran one or seen one in person preform poorly?
And to the origional poster, your cam is WAY small for a 408. It is about the same as a STOCK C5 Z06 cam with a tad more lift. That's right.....a stock cam for a 346 cube N/A motor. I would reconsider how knowledgeable your builder is if he claims 7k+ rpms and 20lbs of boost with this baby cam.
Old 05-21-2008, 04:26 PM
pozesd99''s Avatar
im starting to think that maybe i misheard what the guy was saying. maybe my numbers are messed up hahahaha
Old 05-21-2008, 04:38 PM
ninetres's Avatar
Many VERY seasoned engine builders are "wet-behind-the-ears" when it comes the the LS1 world. They may build one helluva SBC/BBC........but when it comes to late model engines they just haven't learned what works.
Old 05-21-2008, 04:43 PM
Frans96SS's Avatar
i agree... if it was a stock cu in motor it would be nice... but for a 402 its WAY small..
Old 05-21-2008, 04:50 PM
pozesd99''s Avatar
i just talked to va speed and now everything is clear the new numbers are 238-240@.050 .605-.608 on a 115 lsa
Old 05-21-2008, 05:32 PM
bumpin_records's Avatar
well since we are on cams specs let me know if i got the right cam for my setup since its still on the engine stand. I hope its right. THanks Guys
370ci
91.5 turbo
cam specs:
hyd grind# Ls1 373R /372R HR115
intake lift .610
exhaust lift .605
intake duration 242@.050
exhaust duration 238@.050
lsa 115
Old 05-21-2008, 07:03 PM
Websy21's Avatar
There thats allot better, I really like that cam as I said before a few people on here had a comp big cube turbo grind 236/236 115 LSA so thats not too far away.
Quick Reply: just got my cam specs for my 402 ls2 turbo
