Max Boost on a LQ4???
Old May 24, 2008 | 08:25 AM
blazingfast's Avatar
Default Max Boost on a LQ4???
What is the max boost that is being run on the LS based engines? I read some as low as 12 and some as high as 30. I have a iron block studed 408 4340 crank and rods,Tea stage 3 truck heads,E85 blow thru 750 carb, twin T-70s. What is max boost before head lift?
Old May 26, 2008 | 07:50 PM
somebody
Old May 26, 2008 | 09:36 PM
VINCE's Avatar
Shorty Director
Very hard to determine. It is really going to boil down to tuning and octane used. I have seen people lift heads at 12lbs and some that do not lift the heads until 24lbs plus. I think the biggest variable will be your tuning and octane used. Besides each car is different. Just start low and work your way up.
Old Jul 21, 2008 | 10:12 PM
highpockets's Avatar
Approx how much have you seen,max(psi) on your particular setup ? With what fuel ? What CR ? Why are the Supras running 30 psi plus ?
Old Jul 21, 2008 | 11:36 PM
NemeSS's Avatar
10 psi is not of the ordinary on a lq4 engine with a proper tune and 60 lb. injectors
