9" soon... Procharger gear ratio???
Old 07-20-2008 | 10:33 PM
dcvingv6's Avatar
Default 9" soon... Procharger gear ratio???
Hey all,
Figure the FI section would be a better place to ask this question.
I'm looking to order a 9" soon, and curious what most people with prochargers are running.
The new setup will consist of the following:
370" forged iron block
AFR heads
EPP cam
and ~12-14lbs of boost.
Numbers in sig are from a stock bottom end 346 and stock 10bolt
I have the stock 3.42 ratio now, and wonder what others are running.
Should also mention that this is mostly street driven car, seldom will be going to the track.
Any input is welcome
Thanks...
--Mike
Old 07-20-2008 | 10:52 PM
52172's Avatar
I would go 3.50
Old 07-20-2008 | 11:18 PM
HUNTER02SS's Avatar
3.50 for the win!
Old 07-20-2008 | 11:26 PM
dcvingv6's Avatar
thats kinda what i was thinking... was figuring the 3.73 was going to be a bit too high for a FI application...
Thanks...
--Mike
Old 07-20-2008 | 11:39 PM
Avengeance's Avatar
I have 3.70s and with BFG DRs, approx 25" tire, I am deeeeeeeeeep into 4th when crossing the traps at 126mph.
Personally I think the 3.70s are a good choice... I think Ill be fine with a 26" tire.
Old 07-21-2008 | 06:05 AM
EPP's Avatar
EPP
3.70 would be the gear I would go with, especially if you ever end up putting a 28" tall tire on the rear in the future. Bob
Old 07-21-2008 | 09:42 AM
ls 2 goat's Avatar
I've got an 8.8 conversion with 3.55's in it..Jeremy
Old 07-21-2008 | 09:48 AM
98transguy's Avatar
are u keeping the manual tranny or going automatic?either way the 3.70's cruise well on the highway even in an auto
Old 07-21-2008 | 10:37 AM
dcvingv6's Avatar
Thanks for the replies, i am going to keep the 6 speed, so maybe the 3.70 would be the way to go, because I am going to go with a taller tire.
Thanks for all the replies.
--Mike
Old 07-21-2008 | 10:56 AM
98transguy's Avatar
since u are keeping the 6 speed u will have those extra gears and the 3.70's should cruise very well on the highway and still give u some get up and go from a stop
Old 07-22-2008 | 12:01 AM
dcvingv6's Avatar
well, i think my mind is made up, 3.70's it is...
Bob, ill be getting in touch soon!!!
Thanks all for the replies.
--Mike
Old 07-22-2008 | 01:42 AM
Datzneat's Avatar
X2 Bob. This was going to be the first question I ask you lol
Old 07-22-2008 | 05:24 AM
EPP's Avatar
EPP
Sounds good guys. Thanks! Bob
Quick Reply: 9" soon... Procharger gear ratio???
