lt1 with p1sc need combo idea's
Old Jun 1, 2008 | 08:29 PM
qcworm's Avatar
Default lt1 with p1sc need combo idea's
i have an ATI p1sc with front mount intercooler,delteq ignition, 1.6 GM RR's, i wanna do a budget build that will stay together and it is for street use so reliablility is the key hear not really peak numbers.i know i need injectors, tuning and a cam but hwat size i need less than .570 lift with these rockers, the car is a six speed with 4.11's and stock 10 bolt. but with gas the way it is i may g back with a higher gear set. any help would be appreciated, my heads have been decked.020 and ported. and i have a SPEC Stage 3 cluth for it
Old Jun 7, 2008 | 01:37 PM
qcworm's Avatar
no ideas??
Old Jun 7, 2008 | 06:58 PM
99.9percenter's Avatar
Get a used cam,new pistons,new rod bolts.42 pound injectors, get new valve springs the lt4 springs are only good to .525.
Old Jun 7, 2008 | 08:39 PM
Slow94Formula's Avatar
ditch the 10 bolt you put any kind of sticky tire on there and your gonna be running on borrowed time. I have seen a few lsx bolt on cars break them.
Old Jul 17, 2008 | 12:35 AM
qcworm's Avatar
i am actually going to mini tub or back half and 4 link it so the rear end will not be an option, it will be a 9" ford , dana 60 , or a 8 3/4 mopar rear.
