How much boost for a 9:1CR 402?
The project is in the build stage right now and I'm trying to pick turbos and a cam. Anyone got some good cam specs for a turbo engine of this size? I plan to use ported LS3 heads.
Thanks for you input!
Yeah....I'm having a guy at comp spec a cam out for me. Then I'll try to figure the dynamic CR to see how much compression gets bleed off.
Are there any popular turbo cams out there for the 402?
I used the MTI-R1 cam with a procharger and the tuner said, it bumped me up 80 HP, comparing it to other cars with similar set ups. I'd reuse it but I'm not sure how well it will perform with the bigger engine and those heads. I think I need a little more lift.
What turbo are you running?
-Will
