Oil Restriction
Old Jun 5, 2008 | 07:34 PM
otherwhitemeat's Avatar
Default Oil Restriction
So what are you guys with Turbonetics LARGE FRAME turbos putting in for a restriction in the oil feed line to stop it from leaking into the compressor? Right now its a -4 down to a -3 fight before the turbo and its still leaking.....the turbo is past warranty, but it's got less then 1000 miles on it......
Old Jun 5, 2008 | 08:34 PM
DrTurbo's Avatar
LS1TECH Sponsor
Your not suppose to restrict it at all with a BB unit. Only thing you can do is have the front side of the unit rebuilt. Essentially the parts behind the comp wheel and back plate.
Old Jun 5, 2008 | 08:38 PM
Can I get parts seals and or bearings from you and do it myself?....the damn turbo is new! Oh tech support at turbonetics said -3 was fine...
Old Jun 5, 2008 | 08:40 PM
DrTurbo's Avatar
LS1TECH Sponsor
I can check...only problem is how new is the turbo as in when was it built by Tnetics?? The designs have changed a good bit over the past 1.5 year.
Old Jun 5, 2008 | 08:49 PM
I originally got it the feb. 2007......so its probably an old style...oh its was a t91 with an 1.00 Ar and now its got the 101 wheel and compressor cover...that I got from you last june/july...???? and swapped it over.....then a week later wrecked a motor so now it up and running again finally...so I got about 2 weeks driving on this thing I might just have to wipe it off after each time I drive it......
Old Jun 5, 2008 | 09:06 PM
DrTurbo's Avatar
LS1TECH Sponsor
Wow so it sounds like the seal might have lost its tension. They work off tension so once they don't have it, oil comes out.
Old Jun 5, 2008 | 09:20 PM
anything I can do if I pull the wheel back off or something???
Old Jun 5, 2008 | 09:48 PM
DrTurbo's Avatar
LS1TECH Sponsor
Call us tomm....have to check and see what unit you have.
