Two BOVs a benefit??
Old Jun 6, 2008 | 12:21 PM
maxgee's Avatar
Default Two BOVs a benefit??
I'm running one BOV now and have some air backing up to the turbo under light boost (3lbs and under) but works fine under higher boost 5 to 8psi.
I was thinking of adding another BOV for the lower boost levels. Does this make sense to you guys? I can loosen the one I have now, but worried about bleeding off air and boost spikes if I loosen it. Your opinions and suggestions welcomed.
