SDCE Tension
Old Jun 7, 2008 | 09:24 PM
AFASTYZFR1's Avatar
Default SDCE Tension
Just installed my SDCE set up and have installed it twice....first time I set preload to 10 and then the tension was past the 20....so I took everything else and set the preload around 7 and the tension is now at around 18.........it is a brand new belt so I imagine it will stretch a bit but is this tension ok or do I need to re-do it again
Old Jun 7, 2008 | 09:58 PM
BlwnTA's Avatar
7 Second Club
Should be alright for now depending the amount of boost you are running....just keep an eye on it for the first 20 miles or so.
Old Jun 8, 2008 | 01:57 AM
1dirtyZ's Avatar
i wouldn't worry about it that much , like blwnta said, keep an eye on it for the first 20 miles or so , then you're golden
( you're gonna love this tensioner setup! )
Old Jun 8, 2008 | 07:08 AM
AFASTYZFR1's Avatar
Looking for 15 psi.....stock cubes, 9.5 comp, 7.25" crank pulley and 3.4" blower pulley
Thanks guys
Got another question:
Does the idler pulley have to be all the way down...? With the tensioner held back I cannot get it all the way down. It is close to the bottom though
Old Jun 8, 2008 | 05:51 PM
BlwnTA's Avatar
7 Second Club
Thanks guys
No...as longs you have good tension and the belt is not rubbing itself as it goes by your fine.
