turbo oil return line
Old Jun 14, 2008 | 09:14 PM
bumpin_records's Avatar
Default turbo oil return line
how low do your turbo have to be before you ahve to get a scavernger pump. my turbo sits right in front of the harmonic balancer and im draining in the side of my oil pan so yes my turbo is a few inches above the oil pan but i dont know if it have to be way high to use gravity return.
Old Jun 14, 2008 | 09:21 PM
Websy21's Avatar
Sounds like it should be fine, is it smoking at all?
Old Jun 14, 2008 | 11:35 PM
Josh@KY-Turbo's Avatar
As long as your drain line has a downward slope and is not draing below the oil level in the pan while running you will be fine.
Just shoot for a down hill slope and for the drain opening to be above the oil level in the pan. You will be fine.
Old Jun 15, 2008 | 08:05 PM
the car had not been fired up yet. but i will route it like a downslope. thanks for the advise.
Old Jun 15, 2008 | 11:13 PM
DanZ28's Avatar
Good question. So is it also ok to clock the turbo drain a bit (45* or under) or does it need to be straight down?
Old Jun 16, 2008 | 08:18 AM
Old Geezer's Avatar
30*, or less. Preferably vertical.
Old Jun 16, 2008 | 02:41 PM
Websy21's Avatar
I am glad I seen this thread, I guess I need to change some things!
Old Jun 25, 2008 | 05:02 AM
Silverback's Avatar
most turbo manufacturors spec something like 15* or less...
Old Jun 25, 2008 | 03:05 PM
barnat's Avatar
Default An 10 oil return flanges
Ive got some oil return flanges if you need to go with 45s or 90s with AN fittings?? I bought these for my other turbo project that i sold to buy the APS !!if you think these could help ??let me know
http://s243.photobucket.com/albums/f...t/ATP%20Turbo/
