I randomly lose TCS after working with fuel system.
I have some WOT fuel supply problems and we were just trouble shooting the issue. We pulled evap lines, pulled fuses, swapped FPRs, pulled the intank pump and played with that. Standard testing stuff.
So OK, I don't remember ever messing with the TCS system. When I came out of the bowling ally that night after the fuel work I had TCS off and an SES light. The SES light was the throttle position sensor. I open the hood and I forgot to replace the evap line to the evap canister. So I put the evap line back on, removed the TPS cable, replaced it and reset the code. No problems with TPS since. Maybe a total coincidense.
The guys that were helpin me out were looking at my rear at a time, is it posible one of them pulled the TCS plug? Could it have been a fuse in the engine bay fuse box? Maybe it's loose?
Any other ideas? I pulled all the relevant sensors in the areas of the engine bay we were working and replaced them all, but that hasn't helped. I'm looking for any ideas guys.
Thanks,
Mike
That's my guess anyway
You didn't mess with the ABS unit itself did you? Or the front speed sensor plugs?
We were testing voltage on the pump. That would include sticking a paper clip in the connector to get a reading. Yeah yeah I know, real high tech stuff. :p
I'll check back there and see if any pins are out of whack. Thanks for the direction.
Mike
