aps intake duct
Old Jun 24, 2008 | 06:49 PM
Y2KCAMARO's Avatar
Default aps intake duct
in order for the silcone to collapse there has to be a vacuum would removing the air fliters help this problem just about got mine running would like to see max boost out of this kit
Old Jun 24, 2008 | 07:38 PM
10secsts's Avatar
I removed mine about a month ago so I could make some more boost at the track. I made some screens to put over the inlets of the turbos. No problem making boost now. running 14-15psi right now and plan on turning it up to 18-20 if the tranny will take it,lol.
Old Jun 24, 2008 | 08:43 PM
Y2KCAMARO's Avatar
Default aps
sounds good i will try it and see what happens
Old Jun 25, 2008 | 11:31 AM
TNTramair's Avatar
I suggested this awile ago when the whole duct thing came about. removing those air filters should be sufficient enough to prevent them from closing shut. the filters do look to be a little restrictive.
im gonna try the same thing if i ever feel the need to up the boost...
Old Jun 25, 2008 | 12:03 PM
Big Bird WS6's Avatar
well what would be a better filter to put on there.
Old Jun 25, 2008 | 02:58 PM
barnat's Avatar
Honestly,, With the UMI K member that i went with ,,,theres almost enough room to put a cone filter right on the turbo itself. The only down fall i see would be takeing in hot engine air verses the cooler front of the car air not really sure how much this matters? but if mine collapses at 15psi ,where my boost is set ,,thats what im gonna try and do!!Is the cone filters right on the turbos themselves!!
Old Jun 25, 2008 | 05:26 PM
10secsts's Avatar
I've got 10 bucks that says you'll never see 15psi with the intake ducts connected. It might spike to around 14-15 but then will drop like a rock.
Old Jun 25, 2008 | 09:23 PM
Superman09's Avatar
LS1Tech Sponsor
yet APS somehow made 20 or 22 psi on their car....
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jun 26, 2008 | 06:38 AM
TNTramair's Avatar
wasnt that with the bigger turbos though?
Old Jun 26, 2008 | 08:14 AM
Superman09's Avatar
LS1Tech Sponsor
no, it was with their base turbos but a wheel change in it, changed turbo or not, it was still on the standard ducts, no duct change was noted...
__________________
Old Jun 26, 2008 | 01:39 PM
JBrady's Avatar
Duct collapse is not boost related but rather inlet flow related relative to inlet restriction. The result is less pressure in the duct than the atmosphere that surrounds the outside of the duct. When this pressure differential is greater than the physical ability of the duct the duct simply is squeezed smaller or shut by this pressure.
The design of the silicon ducting features a "flattened" section which is MUCH less resistant to colapsing that a round section of the same area. APS appears to be addressing the problem by strengthening that section with more layers of silicon.
While that fix should increase the resistance to collapse it does NOT address the need to eliminate the pressure differential. This differential reduces the power at any given boost and limits peak power potential.
If removing the filters improves this situation the filters are insufficient and need to be replace with better flowing filters.
I think it is a combination of filters undersizing as well as the ducting flow characteristics. If it were my car and I would custom build ducting that would eliminate ANY pressure drop. This is tricky to do on a kit and I understand why APS designed the parts as they did but this is not optimal.
For some good ideas on this check out the APS website and look at the differences in the stock C5 Corvette parts and flow path (same inlet style as the standard C6 ) vs. the C6 ZO6 kit.
http://www.airpowersystems.com/corvette/c5/lhs.jpg
http://www.airpowersystems.com/corve.../z06_eng_l.jpg
Something that would be interesting to know would be what the inside pressure actually is at various engine power outlets.
Old Jun 26, 2008 | 02:15 PM
what about barnet idea. put filter right on turbo? will that work?
Old Jun 30, 2008 | 10:21 AM
JBrady's Avatar
If there was room for a filter that was large enough not to be a restriction... yes... it would work. The reality is that with some effort a decent fabricator could construct ducts that would be colapse proof and also allow enough flow to not create a restriction. That is what APS is trying to do with the new C6 ZO6 kit and that is why I posted the links for review.
