Buy FI set up or a C6 ZO6
BTW, you can always mod the ZO6 if it's not ast enough.
Just my $0.02
Go with the C6 Z06 and enjoy the warranty.
The stock half shafts are weak. Solution is to get a pair of C5 half shafts...
But on the other hand, for about $2,500-$3,000 in mods you can make your C6Z06 put down over 600 RWHP, which is pretty nice.
Its the only thing my friend doesn't like about his C6 Z06, its slow compared to the hundreds of modded cars in his area, he gets walked all the time. But he has head porting/cam change/piston change/exhaust upgrade and a 200 shot in the works....so.....he'll be good to go again soon. He'll have over 800 RWHP on tap.
You can get a 408 on this bored for 4k, Th-400 for 2k, 9" rear for 1500, and a CUSTOM twin turbo kit for under 6k
Thats 13,500k and thats over estimating....
OBVIOUSLY if you can do the work yourself..... and if not add another 3k so 16500 with the work being done by someone else!
People are always linking stuff and saying you can get it for that price. Once you check into things there are almost always other parts you will have to buy to make said item work. The final price that you have paid after you have it in the car will be much higher than what people have listed. A good rule for me has been to take what you think it is going to cost an double it.
1000rwhp turbo kit -3500$...all said and done? Right, I've probaly got 9500$ in my procharger stuff.
6700$ 427 engine...are you planning on putting nice heads, cam, upgraded timming chain, oil pump ect in that engine? My shortblock started off at 4200$ After I upgraded to ARP main studs, ARP head studs, got the better crank, rods, rings ect that 4200$ shotblock ended up being 6000$ If you are anything like me you will want some nice heads...I went with AFR's. The invoice for my heads/cam was 3100$. Add timming chain, high volume oil pump ect ect and I've got around 10k in the engine.
600$ fuel system? I must be stupid. I've got over twice that much in mine.
1600$ for a rear end? I've probaly got 2400$ in mine.
Point is it seems like the people that haven't done this before are the ones that come up with the parts list showing how much each part cost. If you cheep out on everything, do all the work yourself and buy most of the stuff used you MIGHT get it done for 20k. It would take a long time to hunt down the good deals on everything then you would have to piece together the missing parts.
Comming from someone that is currently doing a build like you are thinking about, I say get the C6 Z06. I'll probably have 40k in my build by the time I'm done. That is NOT including the car itself which was 23k back in 02. I would much rather have a lightly modded C6 Z.
https://ls1tech.com/forums/lsx-parts-sale/943060-88mm-turbo-kit-1000rwhp.html
NEW 427 SDPC- $6700
https://ls1tech.com/forums/showthrea...&highlight=427
Powerglide- $650
https://ls1tech.com/forums/showthrea...ghlight=th-400
Moser 12bolt- $1600
https://ls1tech.com/forums/showthrea...light=end+rear
LS1 Forced induction speed inc. fuel system- $600
https://ls1tech.com/forums/showthrea...ht=system+fuel
ODDS AND ENDS- $1000
That would put you WELL over the 850 mark, or atleast should..
That took me about 5-10 mins to source out..
Total= $14050 and no payments!
https://ls1tech.com/forums/showthread.php?t=943060
NEW 427 SDPC- $6700
Powerglide- $650
Moser 12bolt- $1600
BOSS APPROVED!
