sts guys come in!!
Old Jun 27, 2008 | 12:34 AM
99 black ss sj's Avatar
Default sts guys come in!!
just want to know what max hp can a STS GT67 reach with a built 408 cid 9.1 compression any info would be appreciated thanks
Old Jun 27, 2008 | 01:04 AM
BigBlockCamaro's Avatar
Not enough for that motor....
Probably 12-14 psi.. I dont know about HP i would think 600 or so
Old Jun 27, 2008 | 01:40 AM
u mean i would not get as much hp from the sts compare to another kit?
Old Jun 27, 2008 | 01:44 AM
TransAmcoupe98's Avatar
No, he means that turbo is too small for that cubic inch motor. A T76 would be a start with a 408 to make some good power. A gt67 is really good for a smaller c.i. like a 346.
Old Jun 27, 2008 | 01:52 AM
oh ok i got it thanks for the info
Old Jun 27, 2008 | 09:49 AM
02 hawk's Avatar
if's a garrett turbo from sts (67) max 650 at 15 psi....according to sts
Old Jun 27, 2008 | 05:36 PM
vandal0-0's Avatar
Dont even try the 67.I had a 70 from my previous build when I did my 408 and It was way to small.I run a 88mm out back now.
Old Jun 27, 2008 | 05:40 PM
what kind of power are you making with the 88mm?
Old Jun 30, 2008 | 08:01 PM
vandal0-0's Avatar
Havent had a chance to get It tuned yet.I had to leave for Canada for work.So hopefully Ill get It finished eventually.
Old Jun 30, 2008 | 09:42 PM
SSnakekiller's Avatar
Depends on your goals. For your motor, you could easily do a 70 or bigger, but turbo size generally has very little to do with how much boost you can run or how much boost it will take. The nice thing about having a big motor with the 67 is that you may only need 8psi or so to get 600hp, as opposed to maybe 13-14 on a stock ci motor...these are not real figures, just an example.
GT67 will be efficient up to 600-650rwhp. If you want above 650, then you should definitely think about upgrading.
