belt tensioner question
Old Jun 30, 2008 | 10:36 PM
SINISTER's Avatar
Default belt tensioner question
ok i got everything all bolted up need to add fuel and coolent..
my downpipe is a lil close to my belt...its clears but a lil to close for my comfort..
i have the tti alt recloation bracket..
is there any way to switch the tensioner so it pushes forward?? reverse the spring??
or any know if you can take the k tech tensioner and put a smooth pully on it and push it forward?
Old Jul 1, 2008 | 07:16 AM
SINISTER's Avatar
anyone???
i know it sounds crazy but this will give me the perfect clearance that i need
Old Jul 1, 2008 | 07:19 AM
smokinHawk's Avatar
got any pictures on what your talking about.
which turbo kit do you have?
Old Jul 1, 2008 | 07:31 AM
SINISTER's Avatar
its a 6.0 manifold single steup where it y up front like all the others out there
im useing the tti alt relocation bracket from my old tti kit. that tensioner is underneath.
i need to take the tensioner and insted of it putting pressure backwards
i need to add a smooth pulley and place the belt in front and have the tension push forward..
ill look and see if i can find a pic.
MIGHTYMOUSE's Avatar
yep really need to see a photo.
Old Jul 1, 2008 | 07:37 AM
SINISTER's Avatar
im looking...if i can find a pic showing from the old tti street kit with the alt bracket installed is all i need..
i can point and show
Old Jul 1, 2008 | 07:42 AM
SINISTER's Avatar
https://ls1tech.com/forums/attachmen...chmentid=92183
like this..i need the tensioner to go forward and the belt on the other side
Old Jul 1, 2008 | 07:46 AM
i want to see the turbo system you are working around
Old Jul 1, 2008 | 07:52 AM
SINISTER's Avatar
this may work
Old Jul 1, 2008 | 07:55 AM
ooooo, gotcha
yea you could mount a solid tensioner there, but as many belt problems as there are with high mount alterantors, i would expect you to have a lot of trouble keeping the belt on with a smooth pulley on the backside
Old Jul 1, 2008 | 07:59 AM
SINISTER's Avatar
ooooo, gotcha
yeah i thought the same..
this one brian made up along time ago would prob work..
dumb question can i flip the tensioner? looks like he has it flipped?
http://brian.grimal.com/gallery/albu...ket2.sized.jpg
or there is the one from speed inc that dosnt use the tensioner at alll
but that a good chunk of change....for a bracket and a altinator
