forced induction vs. Cam, heads, etc
Let's here the pro's and con's of each
court is now in session. now, if you have the $ to bullet proof the bottom end, and do the rest of the n/a power stuff, oh damn would that make a church lady cry!
I would say the cam, heads, bolt ons, would be easier and more reliable, and instead of 4-5k for turbo you could spend 1k on a good n2o set up and get the same hp................ this is going to be a long thread
I think the decision depends on your goals. FI is a commitment to go fast. It also gives you a ton of power in a very streetable package. If you don't get on it, the cars are typically much more drivable. If you're looking for big horsepower, FI is clearly a better choice than simple heads and cam and can even be more cost effective than a big shot setup. Once you find yourself at the level of spraying enough N20 to require beefing up the engine, this is where I feel the Blowers and Turbos are more cost effective. The engines might be setup differently, but the forging process is all the same.
My biggest knock against an FI setup is reliability. Because our motors weren't designed with FI in mind, I fee for more mild goals it's not the best choice. Even if you sacrifice a little drivability, a heads and came setup might be a better choice for cars shooting <450 rwhp.
So...
coolness factor= FI wins
big horsepower setups= FI wins
reliability on mild setups = FI loses
Just my $0.02
Mike
1) reliability
2) ease of tune
3) no race gas requirement
4) consistent power (I run within 1-2 hundreths back to back)
With the advances in HCI tech now it isn't too hard to get a car running 122-125mph all motor.
With a 100-150 TNT wet kit 130mph in the 1/4 is easy. There aren't too many FI cars making 123mph on a stock bottom end let alone 130mph like HCI cars with small (less than 150 shot)
Chris
Forced induction is great for a show car, or if you want to break into the forbidden land under 10's. The way I built up my motor is to eventually have it running in 9s. If I was to be satisfied with 11s, I wouldn't have done a boosted setup.
Forced induction is harder to tune, and less consistant than a naturally aspirated setup with a big cam and ported heads.
