Rear mount guys. Has anyone thought of this
Being I was thinking of running a hard line for most of the feed I notice I could just cut the evap line that runs to the rear and just attach -4 an line from each end to the block and the turbo . I mesured the lines inside diameter its slightly smaller then a -4 line but I think it will work great .
I think this would eliminate any issue of the line hitting soemthing and dumping all my oil . Has anyone done this ? Dise anyone see any issue ?Also what size an return line should I use ?
Another issue I was worried about was , do you think the hot oil will heat the brake and fuel lines its right next to, enough to cause a brake fade issue of that sort
He blew the seals twice on the dyno with the stock return line they provided(and the stock sts oil pump). Then the turbo was rebuilt again and he went to the big return setup, and it ran great(until the tuner wrecked the motor).
