FI98X Initial Startup movie
who says you can't use 160 lb injectors with a relatively small motor
Fuel pressure is down to 45 psi, that is as low as the regulator will let me go
Driveshaft is on order...should've shipped Friday
Chiseled Performance Water tank with built-in water pump on order (should ship today)
brake lines are fabbed up (double flaring tube really sucks LOL)
measured what I need for flex brake lines and ordered those
parachute mount is powdercoated and reinstalled for the last time
Bought a 54 gal drum of race fuel...
Going back to PAF to finish up setting the suspension with everything in place...looks like I will be actually able to drive it into the shop for the first time in years
should be ready for tuning shortly after
3 weeks looks to be a good estimate to start shaking down...
