My 408 iron block, GT47-88 build.
#64
15lbs. 93oct 16* timing, 10.3 AFR
408ci, GT-47-88, stock 317 heads
http://youtu.be/5lXEUEycOyA
http://youtu.be/yvrIKHyzUZw?hd=1
![](http://www.jpeddings.com/tinkrd/dyno001.jpg)
#67
Cant see second video but OMG on the numbers!!!!!! soooooo nice!!!!
meth or no meth and Comp Ration again please?
ok found it and wow, only 8.4:1 cr. i'll definitely need meth by 15#'s on 10:1 with my very similar setup.
#70
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#73
80lb at 58psi. could probably turn the base pressure down a little to compensate but I'd rather just get bigger injectors.
cruisin
cruisin
![](http://i34.photobucket.com/albums/d133/jaypee1217/5e8550d1.jpg)
#75
Very nice numbers! I have a very similar setup but with l92 heads and 9.3:1 cr and blow thru carb youve given me hope for my dyno numbers. Can't wait to get it on the rollers!
