408/PT98/Six Speed Build
Damn,
You guys better take lots of vids and TX2K9 and texas-mile
Good luck.
VENGEANCE vs S.W WOW
and a small update for those who said I would never spool the 98mm with this combo..... it reaches full boost at 5000 rpm, 8000 shifts.
Take me down to boost lag city
where the spool time is long and response is shitty,
ohhh won't you please take so loooong! yeaaah!
Ok, on a more serious note I don't think it's going to be a very fun car to drive, but anything will spool with enough RPM. If you are going to drag race it you can always build boost with a 2 step / retard. I could see this being fun on the street but not with a 6 speed. If you are after 1700 HP though, this is the turbo you need.
Why not go to an 88mm with the 6spd? Will be much more fun to drive due to having a more useable power band?
What gear did you use to reach full boost by 5000? Would love to see the MPH on a standing mile run with 30psi. Damn 5000rpm is a lot (if your not joking) maybe you should get 3.73 with 315/60/15 in the rear the car will spool faster
You will eventually push water.Your turbo will have no mercy on your motor.
This is why I went with a LSX block this time around.
