bigger guage wire for intank pump??
Old Aug 22, 2003 | 12:21 AM
1dirtyZ's Avatar
Default bigger guage wire for intank pump??
i know this shoulg go in the fueling section , but i'm sure i read this here before , and a search netted nothing. so mods can you keep this here for a few days?
what is the procedure to replace the stock wiring to the intank walbro with bigger guage wire? what guage wire should i use? where to use it? etc.
thanks
Old Aug 22, 2003 | 05:51 AM
smokinHawk's Avatar
Default Re: bigger guage wire for intank pump??
i used a 10-12 gauge wire (with high-temp jacket/oil resistant). Ran that from the aux terminal to a relay. THe relay gets turned on by the old power wire to the fuel pump. I had a 14gauge wire from the relay to the conector (new power wire) to the fuel pump.
Old Aug 22, 2003 | 03:56 PM
1dirtyZ's Avatar
thanks smokin,
did you have the wiring end at the module connector ( top of the sending module ) or did you take it all the way into the tank and to the pump?
Old Aug 25, 2003 | 06:00 AM
smokinHawk's Avatar
first pump, it ended at the conector.
the second pump the wire goes to the pump.
