Incon Actuator Question...
Old Aug 22, 2003 | 10:31 PM
Phate's Avatar
Default Incon Actuator Question...
Anybody know where to get the actuators that came with the Incon kit. I was re-assembling my turbos and setting the actuators to open at 5psi and it seems that I have an actuator with a leak.
Can these be rebuilt or do they need to be replaced?
Thanks,
Scott
Old Aug 23, 2003 | 05:45 PM
red ws6 99's Avatar
Default Re: Incon Actuator Question...
Any Garret dealer should be able to get them, standard garret part.
Gary
Old Aug 23, 2003 | 06:09 PM
Phate's Avatar
Thanks Gary, I will give Precision a call on Monday.
Thanks,
Scott
Old Aug 25, 2003 | 05:27 PM
Phate's Avatar
In case anyone ever needs one of these, I just called LPE and ordered the 5psi actuator that they use on their turbo kits from Ed Potter.
The number that I had on my actuator was 430099-22C...the part number that they had in stock for the 5psi actuator is 430099-10.
I will post again if there is a problem using this actuator, but I am betting that it will be ok.
Old Aug 25, 2003 | 05:31 PM
ChevyNo1's Avatar
I have a spare actuator at home, I'll check the #.
-Dug
Old Sep 4, 2003 | 11:24 AM
Phate's Avatar
Just to let you guys know, the LPE part number appears to be a direct replacement for this actuator and bolted right up!
