Stock long block Lq-9 makes 825/847 to the tires!!!!
#42
Well it looks like its time for new Drag Radials,
Now that we are making 15-17 lbs of boost on the street somewhere around 780 to the tires 1st gear is pretty much useless and second gear only hooks once in a while now, we are hooking up in 3rd gear about 80% of the time, the car just flies on the highway.
Too bad this car doesn't have a Solid Rear and weigh about 700lbs less.
Race weight before the iron block change was aruond 3900 with a 180lb driver
SuperDave
SuperDave
#44
Wow bringing it back up, yes it still runs strong just now on E85 with no meth. It has broke the third T56 just a little while ago, so the 80e is being built now. Eric at Merchant auto is rebuilding the 4l80e and it will get a Vig converter. Should run 9's next season.
#48
About 5k or so since last year. I would guess about 30 track passes or better and a lot of highway runs beating up on exotic cars lol. If it makes it the whole season next year I will be surprised myself. We all laugh at how great it has been and every single pass it makes is one more then I though it had in it lol.
I cannot say enough how important a good tune up, fuel and fuel system is in any FI engine be it stock or built.
#49
I always hear people talk about a good tune, what is the definition of a good tune on a forced induction motor? Is it just common sense like safe duty cycles, ignition advance and afr's? I see guys who can make stock motors hold together and is that the trick?
I see alot of tunes that are conservative with 10.5-11.00afr, 13 degrees timing and running 100%meth, stock rev limit, absolutely no hint of KR is that considered a good tune? I mean a good compromise of power and reliabilty?
#52
that is phuckin nuts...i wonder how long it would hold if you did forged internals, arp studs/goodies, ported heads intake...stuff like that..and how much is this whole turbo kit that you have? how much does a tune cost? will send pm so as not to clog your thread..but damn nice job on a stock engine!!
#53
Yes! Bump lol The power you made is awesome! And inspiring the gto will fly with an 80e. I remembered reading this thread a while ago. I am going from a D1sc to a single turbo and running a stock brand new gm ls2 block, stock crank, clevite bearings, mahle h-beams, je reverse forged pistons, total seal stainless rings, comp 224 228 577 578 114 lsa, stock 317's ls6 and ported tb and all the supporting fuel mods ofcourse. Haha and l was questioning if l could make 750+ going turbo... l made 600rwhp and 520tq on a mustang
dyno at 15lbs and l thought the #'s were a little low. Although that was on a humid 90 degree day. Any imput?
#54
I just got wind of this thread today, man, this is insane!!!!! I have a 99 camaro (all the rest in my sig), looking for 600 rwhp, but sounds like that's gonna be easy. The car's being tuned right now. Best of luck with your ride!!
#55
If you made 600 to the tires through a stalled auto then that is respectable for sure. I am sure you will have a lot of fun with your new turbo setup too.
