My c5 z06 twin turbo 402 dyno session-bleh
How long are you running the car on the dyno before making the pull? I find you need to cruise the car at 2500 for 2-3min before starting the pull (with an STS car) in order to get the entire exhaust system up to operating temp.
If you fire the car up and immediately make a pull after a decent cool-down all of your heat energy will be used to bring the exhaust up to temp rather than bringing the turbos online.
Have you made over 800 hp? Have you tested exhaust gas temps and pressure on manifolds vs. LT's?
I’m new to the rear mount game, show me what your telling me is true, and show me some data.
We did not run the car long, A few fast pull's the we let it sit
After further playing around on the street, and hooking the eboost2 up, we were able to obtain 7 psi at 3k rpm, and 18 psi at 3800 rpm!!!!
By the time i let out at 4k rpm, it had hit 20 psi. I think we have the ability to make the car spool, now its just a matter of getting it to maintain at the desired boost level.
#32
#33
You pull the e-brake (not all the way) to simulate just the right amount of load on the engine while on the dyno... Not the best method, but people do it...
On the Mustang dyno I was tuned on, you can select the load by inputting the "weight" of the car you'd like (in my case, ~3,800 lbs.), and the estimated resistance is created on the roller on the dyno to simulate load...
