100 octane vs. 93....with my setup...
Old Aug 27, 2003 | 11:28 PM
BIGBOS's Avatar
Default 100 octane vs. 93....with my setup...
I'm running a 9:1 compression 6.0L 372c.i. motor....ATI procharger, D-1SC with 12-13psi when all said and done.....I think the car can be safely tuned on 93, but would I see any better gains tuning for 100 only with 12psi....
Old Aug 27, 2003 | 11:43 PM
A DEE O's Avatar
Default Re: 100 octane vs. 93....with my setup...
How much power is your car making on a 93 tune? What does a nice locked third gear pull look like? Hows your car running? I know you've got your *** in it just like me. Well you even deeper! We should hook up sometime. Ang
Old Aug 27, 2003 | 11:46 PM
BIGBOS's Avatar
Right now, I don't know the exact dyno details, I wasn't there when it was going on...maybe intimd8 can chime in if he sees this post, he is the one doing the tuning over at Speed Inc.
What I heard so far is 490-500rwhp and 6??rwtq...thats on 93, not sure how far into the tuning that is, not sure what PSI that is either...
I'm having belt/pulley issues, the car is going into chris sikoras as soon as PSJ's car is out of there....the car is meant to see 12-13, I think its seen a peak of 11psi with the filter on, not sure how high it was pulled on the dyno either....
I'm also dynoing through a TH400 w/a nonlocking 3500 converter, through a 12-bolt on 27" QTP's...
Old Aug 28, 2003 | 12:02 AM
A DEE O's Avatar
Are you driving the car now? How does it feel, run? You'll know if it has 600rwtq. How much boost do you see on the street? Just curious, since I see this all day long?
How much power does the engine make without the supercharger?
Old Aug 28, 2003 | 08:59 AM
Assassin's Avatar
I've seen about an 80-90 hp difference on a FI ls1 compared 93 to 100, could have been higher octane though
Old Aug 28, 2003 | 09:45 AM
CHRISPY's Avatar
I was thinking in the range of 80-100RWHP for sure.
Cheers,
Chris
Old Aug 28, 2003 | 12:31 PM
BIGBOS's Avatar
I'm putting as many miles on the new motor as I can for now, I've been running it on 100 octance since I've gotten it back, its not fully tuned yet, and its been damn hot around here....the car drives great, and it idles like stock, using a 214/218 .540/.550 114lsa cam
I haven't taken it WOT yet on the street....
I'm not sure what the motor is making w/no boost, we never dynoed it....
Old Aug 28, 2003 | 12:56 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I've heard the difference could be 60rwhp.
Old Aug 28, 2003 | 12:59 PM
A DEE O's Avatar
Just was asking because I am fixing to do something with my 6.0l in my garage, just don't know what yet. Good luck with that beast. Ang
Old Aug 28, 2003 | 01:05 PM
BIGBOS's Avatar
Yea, I have no regrets w/the iron block so far...
Just run a CAS radiator and a Spal 16" fan and you will have 170-180 degree temps, not sure if that will be the same w/the turbo manifolds glowing under the hood though....
TTT on the 100 octane tuning issue...
I want some more opinions....
Old Aug 28, 2003 | 01:18 PM
A DEE O's Avatar
We all know why the manifolds were glowing, no timing. How about we lock something in for the next RSD's. I will be on a DR so I expect some spots. $500, maybe. A friendly wager.
Old Aug 28, 2003 | 01:22 PM
BIGBOS's Avatar
We will see.....I've got to figure out a way to get my car to the track....no truck, no trailor....
I have a fear of my belt snapping off a t-brake launch....
Old Aug 28, 2003 | 01:24 PM
A DEE O's Avatar
10/4
Old Aug 28, 2003 | 03:05 PM
Billy the Great's Avatar
buy my dads truck and rent a trailer problem solved
Old Aug 28, 2003 | 05:37 PM
BIGBOS's Avatar
I don't have the cash bill, but I'm sure it will add up to it with what I will be paying for gas...
TTT, I'm sure there are many more out there who have their car tuned on 100 octane...
Old Sep 2, 2003 | 01:18 AM
BIGBOS's Avatar
TTT on this...
