QUestion about larger dispacement engine for FI
a 408 and a 422 will have the same bore, if you punch in the numbers a 4.030 x 4.0 = 408 and a 4.030 x 4.125 = 421. i think the 60 over with the big crank is a 427. lets forget about any heating issues for a moment and ask this question. a 422 is only something like $100 more than a 408 and has the same wall thickness, a $100 is nothing so the real question is which would make more power.
the 3/4 ton radiator is still just a one core but the surface area is huge.
my situation is a little diferent than yours, i will probably have an iron block no matter what, so is it 370? 408? or 422? for me, all with 4.030 bore. figure unlimited amouts of intercooled boost(t88), what would be the quickest with pump gas/ with race gas?
I have the advantage of a light block with more sleeve material.
I had an iron block previously and I took it out. I never liked the added weight and you could feel the difference in the way the car plowed in corners. The new block made an excellent compromise.
Paul
6.0L Iron Block .40" over, stock crank, 372c.i.
I will be running a max of 15 psi when I get the fuel sorted out but I wanted to point out that a big power, big displacement aluminum block can last if built properly.
Once again ARE runs 8.54 on their original 422 and that block has performed flawlessly for 50+ sub nine passes. Why add 100 lbs then have to figure out where to lose it later when you don't have to.
Just my $0.02
Paul
