8/29/03 - Final Pics of mounted Griffin intercooler setup
Old Aug 31, 2003 | 02:22 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Pics of Griffin Race Intercooler + Custom Piping - ALL DONE!
1) Chris made a custom screen for the blower.
2) MAF needed still, perhaps we can discuss that in another thread.
3) Email him and ask him: znines@earthlink.net
Bos, it's in the process of getting wired.
Old Aug 31, 2003 | 03:02 PM
BIGBOS's Avatar
Good deal John, keep us updated....
Old Aug 31, 2003 | 09:13 PM
maddboost's Avatar
so PSJ thats your low boost setup running like 4 PSI right? Now get that car done and shoot me a message when your taking it to the track cause I wanna see the beast run.
Old Aug 31, 2003 | 11:13 PM
smokinHawk's Avatar
Yeah the T-bar clamps are on the list, just could not get them in a timely fashion and so far they are like $9 each from McMaster Carr, anyplace cheaper? I need like 8-10 of them..
mcmaster carr is the cheapest place i found them, cheaper the summit, which is the only other source i know of.
Old Sep 1, 2003 | 10:11 AM
cablebandit's Avatar
I got my clamps at Aeroquip...i think 5 bux each
Do you keep ANY of the foam bumper stuff? I think the intercooler placement is nice if you have some reinforcement still for the nose so it doesn't start flapping in the breeze at 100+ mph
Old Sep 1, 2003 | 10:48 AM
Unreal's Avatar
Napa has tbolts for about $5 or so a piece.
If you can't find them at napa, RRE has them for $6 a pop.
http://www.roadraceengineering.com/hoseandclamps.htm
Old Sep 2, 2003 | 11:00 AM
LS1Tech Co-Founder
I just ordered a bunch of them from Mcmaster Carr.
Old Sep 2, 2003 | 05:15 PM
Guido's Avatar
the road race engineering ones are VERY nice. I bought them for my car and was pleased with their construction.
Looking good John!
Old Sep 3, 2003 | 01:55 AM
BIGBOS's Avatar
Any updates on the car John?
Old Sep 3, 2003 | 01:50 PM
LS1Tech Co-Founder
Everything is done except for the FAST wiring.
The FAST wiring should be done before the end of the week.
Since I have to retain the factory pcm and harness, we also had to keep the MAF for some functions.
Once I can convince Cartek to make a crank signal conversion box that phases the crank and cam sensors I can ditch the pcm and harness.
Brian my car is outside right now.
Old Sep 4, 2003 | 01:04 PM
LS1Tech Co-Founder
Update:
FAST wiring is almost completed.
Most of the t clamps have been swapped on.
Old Sep 4, 2003 | 02:33 PM
  #32
stealth's Avatar
PSJ
I bought Spearco's 3.5x33.5x12 intercooler. Let's compare the two at the next shootout.
Old Sep 4, 2003 | 03:00 PM
  #33
JIMMYZZ28's Avatar
There is no comparison do the math on the area of the core between the two units. Take into account the internal fin design that we use verse theres. We get several manufactures cores and run them against ours constantly. They are just a name and the only reason the have a name is because they sell mass amounts. They dont make specific coolers they just generalize horsepower levels to what they have and put the tanks of your choice on there. We custom tailor to application specifics. As far as heads up i say we get PSJ to throw a fogger system on his ride or talk you into going on a 64 cubic inch diet. Neither of which will ever happen. If you guys want i have a friend with a near 700 hp WRX. Ever try and play catch up to a 4 cylinder AWD? LOL
Old Sep 4, 2003 | 04:29 PM
  #34
stealth's Avatar
A very unfortunate criticism of the world's leading intercooler manufacturer. I asked neutral third parties and the consensus was that Spearco was of much higher quality.
Old Sep 5, 2003 | 04:20 PM
  #35
LS1Tech Co-Founder
Default Re: 8/29/03 - Final Pics of mounted Griffin intercooler setup
Pic of Stealth's car before the ducting was completed:
Old Sep 30, 2003 | 01:52 PM
  #36
JIMMYZZ28's Avatar
John do you have an idea of when you might be dynoing the car. I am in a holding pattern right now in creating any new designs for F-bods right now. I have an S-TRIM bottom/side inlet and center/top outlet being built right now as soon as i have it done i will post it. Also have a couple of radiators i will post some pics of too.
Old Sep 30, 2003 | 01:59 PM
  #37
LS1Tech Co-Founder
Tomorrow.
Old Oct 1, 2003 | 12:22 PM
  #38
JIMMYZZ28's Avatar
Any dyno results yet?
Old Oct 3, 2003 | 01:05 AM
  #39
BIGBOS's Avatar
Stealth, is that bigger than an 8 rib setup, looks like more than 8 ribs, can't exactly see though...
Old Oct 3, 2003 | 07:58 PM
  #40
ZDOG's Avatar
thats just sick!
