FI LSX block machining costs?
Old Aug 16, 2008 | 07:14 PM
BlkHwk's Avatar
So you have tested the LSX and an ERL with the exact same specs side by side on a dyno?
Old Aug 16, 2008 | 07:22 PM
Shawn @ VA Speed's Avatar
i used an aftermarket bbc block with darton sleeves and an aftermarket bbc iron block.the aftermarket alum block was made out of a much higher quality material than the stock ls2 block.the darton sleeve def help ridgidity and bore distortion but dont eliminate it.You have to remember that the alum expands at a much greater rate than alum and is much more flexible.doesnt matter how great the sleeve is if whats holding everything together is flexing and distorting.
Old Aug 16, 2008 | 08:02 PM
NA$TY-TA's Avatar
I can vouch for the testing Shawn has done..... Quite a few things for higher ups that would blow your mind.
Old Aug 16, 2008 | 09:16 PM
sr71bbjr's Avatar
It's not really up for debate...Lsx will always be stronger than a re sleeved aluiminuim. your only as strong as your weekest point. i.e. the aluiminuim that the earl sleeves are sitting in. I think that the earl is a great block from the looks of it..I know steve and the ohio boys give them hell and seem to have great results.I think they both have there place.There is no question that the LSX is more durable though.
Old Aug 17, 2008 | 02:59 AM
99blancoSS's Avatar
Depends on how much you want it bored. For our 434 its $1150 for block and specific LSX work, $1250 for a 454.
Our LSX FI 434 is $6410 and will handle all you can throw at it. (with proper tuning of course )
Old Aug 17, 2008 | 09:44 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Originally Posted by Mr.MartyStone
My ls2 block weighed in at 87 lbs. I've seen the LQ4 blocks are usually right at 180 lbs. If the LSX is 225, that's an easy 140 lbs or so...how much is that worth to you? I think it's definitely worth it, but I'm so greedy with weight I wouldn't know where to begin.
Dang 140 lbs more than my current LS6 block wow. I just got the car < 3400 raceweight.
Old Aug 17, 2008 | 10:19 AM
onfire's Avatar
Coal Mining Director
Warhawk = 133lbs
LS1 = 90lbs
LSX = 225lbs - ~18lbs to bore to a 4.125 = 207lbs.
6.0 Iron ~ 180lbs
C5R block is close to a Warhawk.
Old Aug 17, 2008 | 10:36 AM
NINET3Z's Avatar
Great info Shawn, thanks.
Old Aug 17, 2008 | 11:12 AM
onfire's Avatar
I bet the ERL block is heavier than a Warhawk or C5R block with the stronger interlocking liner... ~ 140lbs.
Old Aug 17, 2008 | 11:49 AM
Mr.MartyStone's Avatar
Originally Posted by BlkHwk
With the well known aftermarket sleeves (darton etc.) cylinder distortion isn't an issue. Not sure how their strength compares to the LSX but I would guess they're just as strong or stronger. Definately stronger than an OEM iron block.
I think the bore would stay much truer but the bores would still shift a few thousandths in the block itself. This is pretty much a known fact when dealing with aluminum motors.
Old Aug 17, 2008 | 11:54 AM
99blancoSS's Avatar
Aluminum expands quicker than iron, iron will always be stronger.
Whats does this do to a bearing, when the housing around it is expanding quicker than the bearing itself? (rhetorical)
Old Aug 17, 2008 | 12:07 PM
  #32
no problem,like i said before i just want people to have all the info so they can make an informed judgement on want they need for their application.I'm def not saying one block is better than another-they both have their place in different applications-it's just matters what you're willing to compromise
Old Aug 17, 2008 | 03:54 PM
  #33
NINET3Z's Avatar
For a Drag Radial car, since you usually have to be at 3400# (+/-), I'm thinking it's worth the extra weight for the LSX block (with high boost). Not to mention it's cheaper.
Old Aug 17, 2008 | 07:00 PM
  #34
BlkHwk's Avatar
Well Said
Old Aug 17, 2008 | 07:12 PM
  #35
PHIL H's Avatar
we have done back to back tests on iron vs alum bbc blocks,on identical 540cid bbc in the 800hp range the alum block was down 30hp and the blowby was greater.seeing how the ls block is lighter and significantly weaker than the big block+adding 20-30 lbs of boost i would think that there would be 100+ hp difference between the 2 at 1500+hp.This could be a major factor in a class that was limited by cid restrictions or turbo size restrictions.those same classes usually have to run pretty heavy so it may not be and advantage to have a lighter block.I'm not saying not to run an alum block-just trying to give all the info so somebody can make a completely informed decision for themselves-not only that,i have an alum block in my own car.
Some of that 30hp loss was also from the loss of thermal efficiency also correct? No doubt on the strength though, i know Moran has always liked the steel blocks better.
Old Aug 17, 2008 | 07:47 PM
  #36
All depends on the car,Phil's car is a little heavier on the nose than i would like @ 3300lbs,but my car @ 3000lbs i have 100 lbs of ballast on the frt to get the correct weight,so the iron block would be perfect-i only have the alum because i had it from another project
Well Said
thanks
absolutely,i can't say exactly how much,but the iron def hold the heat better
Old Aug 19, 2008 | 12:34 PM
  #37
LS1Tech Co-Founder
Originally Posted by onfire
Warhawk = 133lbs
LS1 = 90lbs
6.0 Iron ~ 180lbs
I got some info back from Sean at ERL.
ERL LS2/LS6/LS1 with billet main caps and 4.000 bore: 130 lbs
So looks like 77 lbs is the difference based on Onfire's numbers.
Old Aug 21, 2008 | 08:18 PM
  #38
Bandit28's Avatar
Chinese cast iron is always stronger than ductile iron...
Old Aug 21, 2008 | 11:30 PM
  #39
BoostnTBSS's Avatar
ok just my 2 cents but save the weight!!! cause 25.5 cage to 7.50@3600lbs and to go faster you need to be 3200lbs or less!!!!!! 25.2. ect.. I.E. all the racing going to 1/8 mile... kinda sucks but the lsx will be stronger so there are pros and cons both ways.. in my case i need to add weight to the front so i am going with the lsx block.
Old Aug 22, 2008 | 12:01 AM
  #40
99blancoSS's Avatar
Love the conquest, buddy of mine just picked one up. We're going to build the engine for it. He picked up an EFI manifold system for it as well. Sorry for offtrack post
