boost vs pump gas??
also i have 60 lbs injectors and twin 225s but i have stock lines were is the point when you NEED to change the lines??
and last but not least my motor is 9:8:1 with 6.0 heads plus EPP blower cam im not sure how much this will effect thing but i know yall might need to know this in order to help me out, plus the motor is fully built
any advise here guy/gals???
A guy i know runs 8:37.1 CR and 18 psi with 94 octane, and no meth.
Most i had ever seen out of a d1 was 19psi, we had a 8.65in crank pulley machined and had the d1sc maxed out and over spun. And we still ate belts for breakfast.
i guess the best thing to do is put it on the car and see how much boost it makes and go from there?
But PSI doesnt mean much, a honda can run 17psi on a stock engine all day on pump gas. I'd wory about the power output, IAT and blower cfm and use that as a guide for what fuel to use - not PSI.
Either way you are not going to be able to run a maxed out D1SC on pump gas unless its a 8:1 engine with no timing. Better off slowing the blower down and losing heat/parasitic loss, it will make the same power in the end.
My D1SC was basically maxed out and it was on a pump gas tune(no meth). Got around 16.3 lbs on a 402 with a 228/236 cam. I believe the timing was around 18 degrees. That was with a Ebay special front mount intercooler. The IAT's were up there though.
With my new setup, we will be trying to max out a F1C blower(hopefully no belt slip) on pump gas and meth. But that will be with a larger name brand front mount intercooler.
If by a 'good tuner' you mean a 'good de-tuner' then I agree it can be done
I think the best I ran on the same combo on straight 93 was 9.55 @ 143 or something. ok so maybe this should be the question i should ask if i were to run the same set up as kp was running D1 with a 7.25/3.4 pulley on a 9:8:1 347 with a 232/241 cam and a FMIC and 6.0 heads do you guys think ill be ok or should i get a larger HU pulley and bring the boost/power level down??
I would just slow the blower down, if all you want is 10's you should easily get that on pump gas. I ran 10.40s with a 7.25/4" when I first put the car together and was getting everything figured out and that was like with 12 degrees of peak timing on 9" wide ET streets and 93 octane.
Kp do you think my fuel system is good for this if i so the blower down?
BOSS APPROVED!
