Benefit of a 4" FMIC
Old Aug 21, 2008 | 05:01 PM
JerikSS's Avatar
Default Benefit of a 4" FMIC
Are there any real benefits from upgrading a 3" FMIC to 4" FMIC?? How much will it lower temps???
Old Aug 21, 2008 | 05:11 PM
hellbents10's Avatar
LS1Tech Sponsor
Less pressure drop and more power via lower IAT's.
Old Aug 26, 2008 | 07:59 AM
Vetal's Avatar
But in reality, does it help? I thought last inch of 4" core would help only slightly, if any
Old Aug 26, 2008 | 03:46 PM
DeltaT's Avatar
Depends a lot on the quality of airflow through the FMIC, but it will help, probably in the order of a 10-15% temp reduction and similar drop in restriction.
It also is a large heatsink mass, so on short burst of power, you get a payoff that way as well.
Jim
Old Aug 26, 2008 | 04:19 PM
TurboZ28408's Avatar
quality of core helps a lot. a core with short but many verticle bars would dissipate heat faster plus have less pressure drop than a thicker./longer core
Old Aug 26, 2008 | 04:30 PM
Vetal's Avatar
Will core like 24x12x3 (most common size I think) restrict power at ~800whp?
Old Aug 29, 2008 | 12:55 PM
Vetal's Avatar
Is anyone using 3" core on 800+ hp build?
Old Aug 29, 2008 | 03:25 PM
1320's Avatar
Zombiess probably makes right around there on a good day. It uses a 3 inch core (the ussual) and our next step is to up the cold side pipe area pre itercooler.
I agree with the other guys, that its probably 10-15% in air temp. I get 125 ish with no meth at 15 psi with ambient in 90-100 area. So its probably worth 12-15 degrees....
Does it matter? It does if thats the point that the combustion temp auto ignites.....with no spark. I think theory is that if the combustion temp reaches 660 + or around there (I dont recall forsure) that detonation will occur. So if you at 17 psi and getting 650 combustion temps with a 4 inch core your golden still....but then you swap on a 3 incher and the temps rise to 665.....with the same tune then your wondering why you broke a piston? Or just run 1 less degree of timing?
If you have the room, and the extra 80 or so bucks for the intercooler, and the extra $$ for 4 inch pipe then do it. The 4 icnh pipe might ad another 200 $ to the cold side pipes though.
Old Aug 29, 2008 | 03:55 PM
stevieturbo's Avatar
Yes....
Mine isnt the typical ebay core, but I use a pair of Pace cores that I used to use on my old twin turbo Rover V8 setup.
I cut them up and welded them together to make a single unit. Far from ideal, but it works ok, and didnt really cost me anything.
Old Aug 29, 2008 | 05:18 PM
kp's Avatar
kp
I picked up quite a bit going from an eBay 3" to an eBay 4" but you never know, maybe the 3" was plain 'bad' and the 4" was a good one. But the more mass the better IMO, plus more flow doesnt hurt either..
Old Aug 29, 2008 | 05:29 PM
theblur98ss's Avatar
Was that with the same 3" cold piping or did you up the size of that as well? I'm running the ebay 4" with 3" pipe.
Old Aug 29, 2008 | 06:41 PM
kp's Avatar
kp
Same exact 3" pipes, I just swapped intercoolers.
Old Aug 29, 2008 | 08:36 PM
EPP's Avatar
EPP
Our intercooler kits also use the 4" intercooler with 3" tubing, it kept my car cool at the LSX Shootout last year on the required drive in True Street and the 1/4 mile runs. Bob
Old Aug 30, 2008 | 07:04 AM
Vetal's Avatar
EPP, how much $$$ for 4" IC?
Old Aug 30, 2008 | 08:58 AM
Vetal's Avatar
Could you point me where to look for 4"? I only saw 1 seller on Ebay who has them, but his shipping to Latvia is $280
Old Aug 30, 2008 | 10:04 AM
kp's Avatar
kp
eBay shipping is a ripoff usually, they sell the part ultra cheap and then charge you a ton to ship it. I would PM Bob at EPP and see what he can do.
Old Aug 30, 2008 | 10:41 AM
Vetal's Avatar
Don't know, shipping through USA was $67, but to Latvia - $280, that's a bit too much of the difference
Old Aug 30, 2008 | 06:12 PM
DeltaT's Avatar
Some of that might be import duties, or would you pay that separately?
Jim
Old Aug 30, 2008 | 08:59 PM
Vetal's Avatar
That was just shipping. Taxes would be on top of that
Old Aug 31, 2008 | 08:39 AM
EPP's Avatar
EPP
Shipping overseas is expensive unless you can use APO. Bob
