open flange on divided turbo?
Old Aug 26, 2008 | 10:05 PM
rubbersdown's Avatar
Default open flange on divided turbo?
Can I use an UN-divided flange on a turbo that has a divided inlet flange? I ask because I have a devided turbo on the way and an undivided flange laying around. Also is 3/8 thick enough for a flange?
Old Aug 26, 2008 | 10:06 PM
ninetres's Avatar
Yes you can, and the thicker the better. What size turbo?
Old Aug 26, 2008 | 10:13 PM
its an 88mm from majestic
Old Aug 27, 2008 | 09:01 AM
DrTurbo's Avatar
LS1TECH Sponsor
Ideally you want 1/2" thick....but 3/8's will work. That TV series 88 will make good power, but the 7 blade comp wheel is a little mild on lbs/min flow compared to the new 6 blade wheels.
