Made some more progress on the car...got 8s?
Old Aug 28, 2008 | 01:59 PM
Fireball's Avatar
Originally Posted by 67Firebird455
Same gear I'm running in the 67. Good choice for slightly taller tires, and a turbo!
until you run out of rpm
Replacing with a set of 3.40s
Old Aug 28, 2008 | 03:54 PM
Z284U2TRY's Avatar
I remeber when this car broke into the 10's on a tnt wet kit many years ago. It has come a long way.
Old Aug 28, 2008 | 04:27 PM
Public's Avatar
8's with 20 PSI and lifting, that things a damn BEAST!
Old Aug 28, 2008 | 05:03 PM
DanZ28's Avatar
Congrats!! Thats hauling!
Dan
Old Aug 28, 2008 | 06:39 PM
onfire's Avatar
Coal Mining Director
How much boost at the hit?
Old Aug 28, 2008 | 06:41 PM
Fireball's Avatar
4psi...working on the tune to get it up a bit higher
Old Aug 28, 2008 | 08:57 PM
bgblockelcamino's Avatar
congrats that is awesome
Old Aug 28, 2008 | 09:08 PM
onfire's Avatar
That car is going to be scary fast with a 10psi launch, 1.2x sixty and enough gear to run out the back door.
Heard it here first....go 3.00 in the 9.
 Michael S. Palmer
Old Aug 29, 2008 | 05:45 AM
Fireball's Avatar
nobody makes anything lower than 3.40 in a pro gear
Old Aug 29, 2008 | 09:58 AM
DanZ28's Avatar
Yeah, I was looking for something lower numerically also and went with the 3.40 pro gear as well. I think it will be enough, just may have to run the revs up a bit more.
Old Aug 29, 2008 | 10:06 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
What is your planned shift point with the combo Brian, you are SR?
Old Aug 29, 2008 | 10:17 AM
  #32
NA$TY-TA's Avatar
Bad *** man... Congrats..
Old Aug 29, 2008 | 10:18 AM
  #33
NA$TY-TA's Avatar
Rev's up for what..... u talking about street driving or what because a 3.40 gear and a 30" tall tire are good for 200 mph.....
Old Aug 29, 2008 | 03:26 PM
  #34
black98ws6ta's Avatar
Only at 7700 rpm and zero converter slipage.
10% slipage and you would need to go 8400 rpm to go 200mph on a 30'' tire with 3.40 rear gear.
Old Aug 29, 2008 | 04:10 PM
  #35
DanDan's Avatar
Thats hauling! Congrats!
Old Aug 29, 2008 | 04:22 PM
  #36
NA$TY-TA's Avatar
Doesnt everyone spin it to 8500??? LOL
Very doable with a solid roller setup.
Old Aug 29, 2008 | 09:18 PM
  #37
427's Avatar
427
10% is possible, but might be tough when you are putting 200mph horsepressure to the converter. The lower ratio gears and the high rpm will help lock-up, but 3.40 and 30 inch tires will be testing your converter and building serious heat in the engine and trans. It will get worse if you only have two gears.....
Kurt
Old Aug 29, 2008 | 10:06 PM
  #38
frcefed98's Avatar
Congrats can't wait to see what it does with the right gears in there.
Old Aug 30, 2008 | 12:04 AM
  #39
Navy David SS's Avatar
Very nice -- I went ahead and added you to the list. I know you'll be move up fast...
Pull the chute? It has to feel great to feel that turbo pull all the way (well at least until to the 1000').
Stall? 2-step? What rpm are you launching at? Do you have an "RPM" assist-shifter or do you shift it yourself?
On your build post, you sold your 88. What are you running now?
Anyway one heck of build. Congrats
David
Old Aug 30, 2008 | 07:55 AM
  #40
NA$TY-TA's Avatar
Kurt
Yeah i agree Kurt. It might be close.. LOL.
I know Phil is about 8300 with 3.50 gear on a 30" Tire @ 191mph.
Its going to be a bad *** yr for sure.
David,
Its the FI 98X 98mm
